Anybody with a CK27HST
   / Anybody with a CK27HST #21
Backhoes can be plumbed differently, and are depending on dealer and cost. And there are two different remote kits. I think one kit has detents in both positions, and the other has detent in one while the other position springs back to N when released (but the hydraulic pressure is held). N does mean neutral, but not zero pressure (not float). I have the latter version on mine that controls a rear set of remotes that can be used for anything. I use them for my backhoe and a hydraulic toplink. My 3PH works only with the valve set to N. I've also seen a backhoe plumbed from the loader block on a CK20 and there is some sort of bypass valve that has to opened and closed at the block. I think I've read about the bigger CK's having this setup too. Not sure of all the details on it. Though, I think it's done to save the cost of adding the remote.
For the OP, be happy. You have a rear remote setup. Now get a backhoe, log splitter, hydraulic toplink, hyd down pressure post hole digger, hyd steerable snowblower, etc. and put it to good use. Then you'll want to add a second remote for hyd angle and toplink at the same time:)
Thanks for the replies, people.
Cement mixer with hydraulic top link coming soon.
JLG 1255 Telehandler (A55315)
JLG 1255...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
