Anybody Weld With Batteries
   / Anybody Weld With Batteries
So I brought the gate home and repaired the damage, but the gate post is not plumb. It was that way before, and I offered to repair it. But I need to do just a little cutting on site and maybe four inches of welding. This job is two hours away, so the logistics become expensive. My time and driving a 3/4 ton truck. At the end of the day, the bill can't be too high, and I want to make some money. Buying another welder won't accomplish that.
   / Anybody Weld With Batteries #22
Rent a bigger generator to use your existing welder. Just explain your cost to the customer
   / Anybody Weld With Batteries #23
Here is an example of battery welding.
Batteries + Jumpercables = DC Welder
Much more refined model that I think was mentioned earlier in the discussion. Pretty slick.
Ready Welder
I've always gotten a kick out of these lawnmower welders.
Do It Yourself Engine Driven Welder
Some even keep the tractor intact and just remove the deck and put a welder/generator head in it's place. Pretty slick portable riding welder. LOL.
Thanks for that. I can't imagine using anything other then the best quality jumper cables if you are going to go that route. I once heard a story of a guy screaming, waving his hands frantically, because the cheap thermoplastic jumper cables he was using to boost something got hot and the hot molten plastic was now all over his hands!
I even happen to have a Fluke DC clamp on meter in case I want to see what the current is, although tht would be hard, while welding. It does store MAX values.
   / Anybody Weld With Batteries #25
I think you will find that the starting current drawn by a V8 on a cold morning is about three times what you will need to weld6011....
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1980 Gleaner F2 with heads (A55302)
1980 Gleaner F2...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
Komatsu PC88MR-8 (A47477)
Komatsu PC88MR-8...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
