Any woodturners out there?
   / Any woodturners out there? #11
I would love to have one, but floor space required vs actual use gives me qualms.
Yes for sure... I am already maxed out on floor space and I am thinking of a lathe before my shop build. My dad always said my priorities were backward.
Yes, levers vs. nut adjustment I get it. Need to be looking for that feature!
   / Any woodturners out there? #13
I am readying to buy a wood lathe. Looking at a mid size 16x24 Possibly a Nova Saturn DVR. Not sure I need/want a full size lathe for say, table legs as I plan to do more bowl turning type of work. Question... do you think I will kick myself for not splurging for a full size? I guess the question is how many of you turn long pieces vs. short for the various projects you do?
Mark, I have two full-size wood lathes and do a fair amount of turning. Mostly bowls, but many little things as well: wine bottle stoppers, ice cream scoops, salt shakers, pens, pendants, etc. As you probably know, you can easily turn small things on big lathes, but not vice versa.
The Nova Saturn DVR is a nice lathe, but you sacrifice motor power, lathe mass, and of course bed length. 24" between centers is pretty short. These things will become more important to you if you continue your enthusiasm for turning, and they don't call it "the vortex" for no reason. :laughing: Even if you don't plan on doing long spindle work, sliding the tail stock out of the way without have to remove it is a big plus.
If you're already considering spending $2,000 on the Nova, I'd take a serious look at the Grizzly G0766 for $250 more. Very beefy cast iron bed, headstock and legs. 22" swing, 42" between centers. The 3hp motor and the Delta Electronics VFD M-series drive are a nice combination. It also now comes with a larger, redesigned banjo, and slightly shorter legs to reduce overall height than at initial roll out in 2013.
Also have a look at the Grizzly G0733 for $1,950. 18" swing, and 47" between centers. 2 hp motor. I hear that it now ships with a handwheel, which it hasn't had in the past.
Thanks 3pt. I am now visualizing the Nova 16x44 Galaxi DVR in my shop. Found it tax free and shipping free direct from the Nova warehouse via Tools-Plus.com for $2349 delivered! All other sites (Amazon, Woodcraft, etc) I would be in for about $2950 or more due to state tax and shipping fees. One thing I do like is the 110/220v convertibility. In my current shop I am hampered for power and need my single 220v for my compressor. I also like the 360deg swiveling head stock allowing larger than 16in work, and the direct drive motor with instant stop.
Although not quite as beefy as the Grizzly G0766, I think it will have the weight (436lb) and power (2.3hp at 220v) for my needs. Also a much better warranty and no belts! So ready to pull the trigger.
NOVA GALAXI DVR LATHE (SKU 55214) - NOVA
   / Any woodturners out there? #15
I’m not sure that no belts would be a bonus. That’s sorta like having a single speed HST tractor. I doubt you’d ever use the swiveling head stock. Maybe if you’re into turning serving platters but anything of any weight would be asking a lot of the lathe. I doubt you’d have any problem running the lathe and air compressor at the same time on the 220 volt circuit especially of it’s a 30 amp one.
Actually I was thinking the swivel would be great for better access inside taller bowls. But I am a novice so at this point, just shootin' my mouth off.
As far as my 220v service to my garage... I'm embarrassed to admit I am running a heavy duty extension cord from my dryer outlet (not needed because I have a gas dryer) from my house to the garage! :ashamed: My welder and plasma cutter also share that line.
:smiley_aafz: Yep, need a new dedicated shop!
   / Any woodturners out there? #17
It might if it didn’t compromise the tool rest stability. Or of you had a sliding headstock you could just slide it almost to the end. Btw I’ve got a supernova chuck and a Oneway stronghold and the oneway is by far the better one.
   / Any woodturners out there? #18
Don't we all, I thought I was in heaven when I moved out of a 1 car garage to a 6x12m shed, 12 years later it is overflowing and I suspect if I had an aircraft hangar it wouldn't be any different.
I put in 15a outlets so I can use a welder and a plasma cutter, our outlets are generally 10a and no regrets there but we only run 220v or 3 phase (I don't have 3 phase).
The plugs are identical but the 15a has a big earth pin and won't fit into a 10a outlet, a lot just file down the pin.
Pickup Truck (A59230)
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
