any well drillers around??
/ any well drillers around?? #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
Our well has functioned flawlessly for the past 3.5 yrs.. BUT in the last month we have had problems. Our well is 340 feet deep, has 3 water sources, pumps about 4 gallons per minute, and waters is within 50 feet of the top.
Problem #1 - the whole house filter was getting clogged with 1 or 2 days (previously would last 1.5 to 2 MONTHS)
Solution - installed 'sand filter' around pump and raised the pump up about 15'
After this the water was VERY dirty so we used it alot and the water cleared up considerably.
we have been gone a week and thought that any remaining particles in the water would settle out during that time but it hasnt
Problem #2 - Water is still slightly brown, but the whole house filters is clogging with fine mud now after 1 day.. There is no smell to the water though.
Any thoughts or ideas on why or what do to fix this?
Brian
/ any well drillers around?? #2
Sorry I can't offer any help but I'm interested in what others have to say about this.
We just had a well put in at our place in Maine and the water is cloudy brown looking. I'm hoping I don't have to filter it and that it eventually will run clear. The well is 180 feet deep and produces 15 gal/per/min.
/ any well drillers around?? #3
Brian, what do you mean by "3 water sources"? Are you saying that water feeds into your well from three different depths? Is your well cased all the way down to near the 340' level or is it only a partial casing? In my area, the drillers go to great lengths to seal all water sources except the deepest one that's in water producing sands. They run a casing down deep and seal around it. If you have constant mud in your water, I'd bet one of your sources is clay contaminated or your well is silting in from the bottom up at a high rate. I'm not a well driller, so my opinion is just as an observer and may be incorrect, but muddy water in a well would sure seem to indicate a new source that is washing in mud or a silting of the well. Also, is it possible that you have a long run of plumbing with sand in it? Do you maybe need to backflush between the filter and the well? If your filter is some distance from your well, it might be possible for the feed pipe to have dirt that is slowly collecting in the filter.
/ any well drillers around?? #4
We have always had lots of sediment. I had the well driller come out about 2 years ago and had him raise the pump about 20' which helped a lot.
He said the most sure-fire way to cure sediment was to pack the well with gravel. I was very reluctant to do this because it meant the pump could never be pulled and replaced.
I think a lot of this is local conditions and you need a local well driller. Get several opinions before you settle on one.
"3 water sources" is what I understand to mean they hit 3 veins of water when drilling.. Im not sure how many are still feeding the well.
I am not sure how far down it is cased either.. I called the drilling company and the receptionist was going to contact the boss and see what he suggests.. Ill ask when i talk with them again.
When the pump man pulled the pump when the first problems came up, he said that the 'check valve' in the pump had failed and the water coming back down the water line was what caused the 'disturbance' in the water.
the sand filter had kept the bigger grains of sand/grit out of the whole house filter. but now its the mud that is the problem.. Previously we never had the mud problem in the filters..
the water comes into the expansion tank then thru the whole house filter and then to the rest of the house.. IF i wanted to try and pump out the muddy water, could i turn the valve off between the whole house filter and the expansion tank and then hook a hose to the drain valve on the expansion tank without hurting anything? That way i can keep the muddy water out of the house lines easier until it clears up.. Would that work?
thanks for the ideas
Brian
/ any well drillers around?? #6
thatguy;1994797 IF i wanted to try and pump out the muddy water said:
It should work. You may rinse a lot of ook out of your pressure tank too, a good thing.
Dave.
/ any well drillers around?? #7
Brian, please don't take my word as "gospel" on wells. I'm just brainstorming what and where you could have problems. I do know that like CurlyDave suggested, my well driller filled in my well void with about 1-1/2 yards of pea gravel and then concreted the top for a good seal. He listened to the sound of the gravel going down around the casing and could tell when it quit hitting water, indicating it was above the level of standing water inside and outside the casing. After that, he set my pump up about 25' above the bottom of the well and told me to pump steady for 7 to 10 hours. He had used Dawn soap as a drilling lubricant and it took awhile for suds to quit forming in the water coming out. Then, the water cleared completely and has been crystal clear since.
If your three water sources are near the bottom of the well and all part of the same aquifer, then what I'm saying could be bunk. However, if you have several sources throughout the depth of your well, then I don't see how that could ever be a good thing. How would you ever know which might be causing the problem or how to stop it?
EDIT: One other thing...
With a little research, I found out that the aquifers in your area seem to be from fractured rock and most wells are around 400' deep with production around 10 gpm. I also noted that your City Council had a recent request in January of this year regarding a housing development that could introduce many new wells into the aquifer. Have you checked with neighbors regarding similar problems with their wells? Is it possible that a recent housing development might have "stirred up" mud in the aquifer due to many water wells being drilled in the same area with your well being downstream?
/ any well drillers around?? #8
Is the "mud" gray in color?
When we had the well drilled for our house we had gray in the water it is clay
sediment. We had to put in a 300 gal water tank and inject the incoming water
with a coagulant, This caused the clay to settle to the bottom of the 300 gal
tank and we draw water from the tank about 1/2 way up the 300 gal tank.
Every month we open a valve on the bottom of the 300 gal tank to get the clay sediment out so it does not build up.
You can call a local water treatment service or call Culligain they will be able to
tell you what is in your water and how to treat it.
/ any well drillers around?? #9
What type of ground is it drilled through?
This will help us give you better answers.
Could be something as simple as a new water vein has opened or closed. Could be sucking water from further away. Blasting in the area or an earthquake all could cause problems.
In our area lots of wells have a Sulpher smell. My well is drilled 160 feet through shale; we used to get grey water sometime so bad you could not see your finger in the middle of a glass of it and that was using a 1 micron filter. They called it rock flower or shale water. Had to finally put in a $6,000.00 filter system. Now our water is filtered to .014 micron and it's clean.
/ any well drillers around?? #10
Three water sources.... generally speaking, a well is drilled thru layers of different type of lithologic formations.. clay, shale, sand or sandstone, etc... it is not uncommon for a well to penetrate more than one water bearing formations... see if you can find the original drillers log, which should list the formation/material drilled thru. It's possible that if the bottom of the borehole is left open hole (without casing), you could have some clay/shale sloughing off and disturbing the water in the well. Without knowing where your well is cased, the pump setting, static water level, it's all guess work.
A good well contractor should be able to diagnose your problem and come up with a solution.
/ any well drillers around?? #11
While I am not an expert,let me share what a neighbor had to do..
Her well is only 260 feet and gets a fair bit of silt. It is about 500 feet from mine in the same line and I would guess same water vein.. But it is about 40 feet lower than my well head. (my well is 465 feet deep).
When they drilled it, the well company put in a backflush filter. (that is what they called it) and then added a hose bib connection for a water hose.
The neighbor told me that she is adding another hose bibb on the outside of the house later...
For now--once every couple months she goes down and opens the backflush valve up in the basement, and then has a water hose out a nearby basement window to water her flowers etc or whatever.. not sure what she did this past winter, but it was really clogged when I went down the other day...
With all that said-- how about this---
Get one of those flushing filters, (I was told Lowes has them for $100) and then add a good automatic timer...
With an outside freeze resistant hose bibb, the timer, a backflow preventer and the "flushing filter" set it up so that it comes on and runs for X time for X days when your not home or at night..
Maybe do it for 30 min or 1 hour every night for a week and see how that helps...
It would be a bandaid at least...
I have those throwaway filters, and it works ok- but every 6 months or so...ugg... $20...maybe I will spend the $150 and do my own suggestion before summer is out......
J
to give you some more details.. I talked with a local pump company that has a camera but with the water so murky/muddy he said that they probably could not see anything.. After telling him the back story he was not sure what may be going on..
he suggested flushing the well out for at least 7 or 8 hours - or even overnight.. I have a hose hooked to the bladder tank and set so it is putting out about 2 gals/min..
I also got other details about the well.. 340' deep, 88' of PVC casing, output 6 gal/min, hit a water zone at 95', 170' and 210'.. everything past the casing is in granite.
thanks for the help
Brian
/ any well drillers around?? #13
Brian,
I would be curious how deep the 88 ft of PVC extends into the granite..
If there is not an overlap... could sand go past the PVC and get into the granite depths?
J
quick update.. I ran the pump for about 7 hrs last night and the water has really started to clear up.. Still not sure why it was so muddy though.. I reckon we will have to wait and see if it turns muddy again and if it does its time for the camera..
BTW - I pulled a water sample when i started my pump out and 24 hrs later the particulates have separated and settled to the bottom.. Does that mean it is probably dirt and not some other substance?
thanks for all the advice - i hope this fixes it..
brian
/ any well drillers around?? #15
Means the particles are larger and heavier in the silt range. Clays may stay in suspension for very extended periods of time depending on their size.:)
/ any well drillers around?? #16
brian
Brian, that's good news. I hope your well continues to produce as it should. Maybe it was a one-time shift of something that stirred up a lot of silt in your pool and you now have it cleared out, at least until the next "event."
/ any well drillers around?? #17
Also you may have sand sticking the check valve open slightly which when the pump kicks on pressurizes the bladder tank and then shuts off as the pressure builds. the water under pressure squirts out back into the well hitting the sidewall and rinsing off clay/sand/silt into the water in the well bore. this can also happen when a small hole wears into the piping.
one way to test this is to run the water until the pump kicks on the watch the pressure gauge and close the main shutoff valve and keep an eye on the pump gauge. if it starts going down leakage is going someplace back into the well. at that point you may have to call service person to pull the pump and check out the pump check valve and the line leading up into the home.
other possibility you are already working on is the incoming water is rinsing in the clay silt under normal use the aquifer is clear but ground disturbance earth quakes and someone drilling near by can really cause a problem in the aquifer. a neighbor of an old friend had a major problem after a NEW well was put in about 1/4 mile away. they tapped into the same aquifer and polluted their well for months. it did very similar to what you have happening.
post back when ya can
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
John Deere 6300 (A60462)
John Deere 6300...
429872 (A61166)
429872 (A61166)
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
