Any way to push around a JD300 HST lawn tractor?
   / Any way to push around a JD300 HST lawn tractor? #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I'd like to be able to roll it into / out of the shop every now and then.
But with the HST must I start it? or is there some way to easily get it "out of gear" ?
   / Any way to push around a JD300 HST lawn tractor? #2
Look on the back for a knob to pull... there should be a way to put it in neutral but I'm not sure about your actual model.
   / Any way to push around a JD300 HST lawn tractor? #3
Get a manual, our 425 had a lever in the back, you could use, but you had to keep it depressed, yours may well have one also.
   / Any way to push around a JD300 HST lawn tractor? #4
If by chance this is the X300 (and not a different 300), then there is a lever/knob on the rear to pull out.
And a link to the manual.
OMM155820-H6
   / Any way to push around a JD300 HST lawn tractor? #6
There's a knob in front of seat that one turns CW to depress the 2 valves(parts key 18) so tractor can be towed/pushed.
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
