Any way to push around a JD300 HST lawn tractor?
   / Any way to push around a JD300 HST lawn tractor? #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I'd like to be able to roll it into / out of the shop every now and then.
But with the HST must I start it? or is there some way to easily get it "out of gear" ?
   / Any way to push around a JD300 HST lawn tractor? #2
Look on the back for a knob to pull... there should be a way to put it in neutral but I'm not sure about your actual model.
   / Any way to push around a JD300 HST lawn tractor? #3
Get a manual, our 425 had a lever in the back, you could use, but you had to keep it depressed, yours may well have one also.
   / Any way to push around a JD300 HST lawn tractor? #4
If by chance this is the X300 (and not a different 300), then there is a lever/knob on the rear to pull out.
And a link to the manual.
OMM155820-H6
   / Any way to push around a JD300 HST lawn tractor? #6
There's a knob in front of seat that one turns CW to depress the 2 valves(parts key 18) so tractor can be towed/pushed.
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
2011 Honda Pilot EX SUV (A53117)
2011 Honda Pilot...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
19?? Asphalt Roller (A52377)
19?? Asphalt...
