Any way to push around a JD300 HST lawn tractor?
   / Any way to push around a JD300 HST lawn tractor? #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I'd like to be able to roll it into / out of the shop every now and then.
But with the HST must I start it? or is there some way to easily get it "out of gear" ?
   / Any way to push around a JD300 HST lawn tractor? #2
Look on the back for a knob to pull... there should be a way to put it in neutral but I'm not sure about your actual model.
   / Any way to push around a JD300 HST lawn tractor? #3
Get a manual, our 425 had a lever in the back, you could use, but you had to keep it depressed, yours may well have one also.
   / Any way to push around a JD300 HST lawn tractor? #4
If by chance this is the X300 (and not a different 300), then there is a lever/knob on the rear to pull out.
And a link to the manual.
OMM155820-H6
   / Any way to push around a JD300 HST lawn tractor? #6
There's a knob in front of seat that one turns CW to depress the 2 valves(parts key 18) so tractor can be towed/pushed.
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Cub Cadet ZTT i1042 Lawn Mower (A53117)
Cub Cadet ZTT...
Kubota BX2230D (A47384)
Kubota BX2230D...
