Any tips on re-wiring a tractor?
   / Any tips on re-wiring a tractor? #1
SOLIDEAGLE
I've got my YM240 all torn down waiting on some warmer weather to repaint it and I figured I'd run all new wires on it. I've never rewired a whole system before and I was wondering if anyone has any tips to make this job turn out right. Thanks!!
   / Any tips on re-wiring a tractor? #2
Since all wires are color-coded, the only way to do it right is to find a complete wiring harness, which is probably impossible; otherwise you are looking at a troubleshooting disaster unless you can use and label a different color wire for each replacement.
   / Any tips on re-wiring a tractor? #3
I assume you have the YM240 wiring diagram. Norm and I post it from time to time.
Here it is again, just in case.
   / Any tips on re-wiring a tractor? #4
wiring is one of those things that you start early in the morn and STICK with it. Looks like you have a good diagram from California, seems fairly simple to me????? Of course as the day goes along you'll end up saying "NOW what was that &^%&% yellow/blue/red/brown wire for !!!" :D
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
