Any tips on re-wiring a tractor?
   / Any tips on re-wiring a tractor? #1
SOLIDEAGLE
I've got my YM240 all torn down waiting on some warmer weather to repaint it and I figured I'd run all new wires on it. I've never rewired a whole system before and I was wondering if anyone has any tips to make this job turn out right. Thanks!!
   / Any tips on re-wiring a tractor? #2
Since all wires are color-coded, the only way to do it right is to find a complete wiring harness, which is probably impossible; otherwise you are looking at a troubleshooting disaster unless you can use and label a different color wire for each replacement.
   / Any tips on re-wiring a tractor? #3
I assume you have the YM240 wiring diagram. Norm and I post it from time to time.
Here it is again, just in case.
   / Any tips on re-wiring a tractor? #4
wiring is one of those things that you start early in the morn and STICK with it. Looks like you have a good diagram from California, seems fairly simple to me????? Of course as the day goes along you'll end up saying "NOW what was that &^%&% yellow/blue/red/brown wire for !!!" :D
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
John Deere 650K Dozer (A52377)
John Deere 650K...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
