Any reviews of this multiplier?
   / Any reviews of this multiplier? #1
turkish
This looks like just what I need. I need one more remote for very infrequent use. I looked around for reviews on this particular unit and didn’t find any. Looks identical to the Summit unit, but it comes with a mounting bracket. Thanks in advance for any input or suggestions for a more proven analog!
   / Any reviews of this multiplier? #2
I know they make other quality accessories. I have a brush guard from them, and it is very well built and a perfect fit with stainless hardware.
I suspect they manufacture the rops bracket and outsource the multiplier.
   / Any reviews of this multiplier? #3
Looks like there is a manual valve that you have to operate to change which circuit is active vs others that have solenoid operated valve operated by a pushbutton on the direction control lever so easier to select which circuit operates
   / Any reviews of this multiplier? #4
Ditto what @oldnslo says. I wouldn't call it a "multiplier". It simply switches between two outlets. As it says, "Rotate handle 45° to toggle between circuits". You still only have one circuit available at a time. It didn't multiply the circuits, just the outlets.
   / Any reviews of this multiplier? #5
All kinds of them on Amazon, including the Summit version. I used the electric version for my front snow plot and tree puller. Manual version is handy on my round baler for gate and twine tie from a single lever. Manual deal was $120.
   / Any reviews of this multiplier? #6
I can see where this manual version would be handy on an open station tractor, but you would need a solenoid operated unit for a cab.
Don’t know what to tell you. I didn’t make up the name of the product.
   / Any reviews of this multiplier? #8
I have the one from summit which is a little less expensive but doesn’t come with the bracket. Since it plugs into the back remotes which are bracketed an additional bracket isn’t needed. It’s a quick and relatively simple way to manually divert between the top link on the back and the additional remote on the front that controls the snow plow tilt.
   / Any reviews of this multiplier? #9
Yours plugs directly into an existing remote just as an implement hose would? I have hesitated in getting a similar device because I don't want the hassle of removing a set of remotes and plumbing and mounting the manual splitter.
Do you have a photo or a link to what you have?
   / Any reviews of this multiplier? #10
That's exactly how it connects. Summit supplies a couple of eccentric connectors that can be adjusted to the distance between your current remotes. Manual Hydraulic Multiplier, SCV Splitter / Diverter Valve Kit with Couplers, NPT
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
CATERPILLAR M322F...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
