Any reviews of this multiplier?
   / Any reviews of this multiplier? #1
turkish
This looks like just what I need. I need one more remote for very infrequent use. I looked around for reviews on this particular unit and didn’t find any. Looks identical to the Summit unit, but it comes with a mounting bracket. Thanks in advance for any input or suggestions for a more proven analog!
   / Any reviews of this multiplier? #2
I know they make other quality accessories. I have a brush guard from them, and it is very well built and a perfect fit with stainless hardware.
I suspect they manufacture the rops bracket and outsource the multiplier.
   / Any reviews of this multiplier? #3
Looks like there is a manual valve that you have to operate to change which circuit is active vs others that have solenoid operated valve operated by a pushbutton on the direction control lever so easier to select which circuit operates
   / Any reviews of this multiplier? #4
Ditto what @oldnslo says. I wouldn't call it a "multiplier". It simply switches between two outlets. As it says, "Rotate handle 45° to toggle between circuits". You still only have one circuit available at a time. It didn't multiply the circuits, just the outlets.
   / Any reviews of this multiplier? #5
All kinds of them on Amazon, including the Summit version. I used the electric version for my front snow plot and tree puller. Manual version is handy on my round baler for gate and twine tie from a single lever. Manual deal was $120.
   / Any reviews of this multiplier? #6
I can see where this manual version would be handy on an open station tractor, but you would need a solenoid operated unit for a cab.
Don’t know what to tell you. I didn’t make up the name of the product.
   / Any reviews of this multiplier? #8
I have the one from summit which is a little less expensive but doesn’t come with the bracket. Since it plugs into the back remotes which are bracketed an additional bracket isn’t needed. It’s a quick and relatively simple way to manually divert between the top link on the back and the additional remote on the front that controls the snow plow tilt.
   / Any reviews of this multiplier? #9
Yours plugs directly into an existing remote just as an implement hose would? I have hesitated in getting a similar device because I don't want the hassle of removing a set of remotes and plumbing and mounting the manual splitter.
Do you have a photo or a link to what you have?
   / Any reviews of this multiplier? #10
That's exactly how it connects. Summit supplies a couple of eccentric connectors that can be adjusted to the distance between your current remotes. Manual Hydraulic Multiplier, SCV Splitter / Diverter Valve Kit with Couplers, NPT
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
207280 (A52708)
207280 (A52708)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
