Any news on gas engine CUTS?
Status
Not open for further replies.
   / Any news on gas engine CUTS? #141
Let's hope she never needs glow plugs or injectors past warranty .
DI gas injectors are not any cheaper, and are just was fragile. Can you remind me again how you plan to legally fuel you DI gas tractor without driving it to the pump or slaving away 5 gallons at a time? How many spark plugs and coil packs have you had to change on a diesel? How many plastic intake manifolds with active variable intake runners (at $1700 each) have you had to replace on a diesel? How many times have you had to clean the garbage out of a throttle body on a diesel? Ever had a mass airflow sensor or idle air control give you **** on a diesel?
I can go on all day long. Just say when you finally see my point. DI gas engines and their 50 required sensors and circuits with fragile electronic controls DO NOT belong on a working tractor.
   / Any news on gas engine CUTS? #142
The EPA mileage tests are an even plying field to obtain and apples to apples comparison of mileage. Who should be believed about a machines performance? Lab techs using calibrated equipment under known repeatable conditions ? Or what some Bubba on the Internet or down at the tavern says his vehicle is getting for mileage?
I laugh at most EPA fuel consumption listings! To this day I haven't gotten the MPG they ESTIMATED on a vehicle I purchased. I know I am just some BUBBA on the internet but since I have built more engines than I can actually remember I figure maybe just maybe that counts for something!
   / Any news on gas engine CUTS? #143
So testing a car on a dyno equals "Lab techs using calibrated equipment under known repeatable conditions". I guess in a way you are right. Dyno will give the same numbers for the car every time. How that translates to "real world" conditions is beyond me.
A little info for those who haven't spent any real time with a Dyno. If you put a car on a dyno and test it today you will get one number. Leave that same car on the dyno till tomorrow morning and test it again and you will get a different reading. Most folks would be surprised at the difference I can obtain just testing their car at different times of the day without making any changes to the tune.
   / Any news on gas engine CUTS? #144
Yeah that got me thinking of the ford Gas -diesel comparisons like the early Ford 2000 series with the 158 gas and diesel engine.
diesel pto hp 32.09hp gas 30.85 hp
draw bar hp diesel 28.10hp gas 26.49hp
Fuel consumption Gas 10.79 horsepower-hours per gallon
diesel 14.23 horsepower-hours per gallon
Major difference in fuel operating cost...
Back in the 1960's with carburators and when diesel cost less than gasoline . What has the pump price of diesel vs gasoline been since 2006?
Are you at all familiar with the design and operation of a DI gasoline engine vs a carburated gasoline engine ?
Are you aware how much improved the thermal efficiency is of a 12.5 to 1 DI gas with variable cam timing vs a 7 to 1 carburated gas engine ?
   / Any news on gas engine CUTS? #145
That is why the pro labs note the temperarure, humidity and atmospheric pressure . Should see the difference the weather makes on the take off distances for aircraft.
Running the dyno oil at the same temp makes a difference too.
   / Any news on gas engine CUTS? #146
Hutch. Re post #132. If manufactures are all cheating and inaccurate as Hyundi with over rated mileage.How does so many drivers here exceed the EPA numbers ?
   / Any news on gas engine CUTS? #147
Some diesels do have a mass air flow sensor .
No problems with the MAF sensors here since the 1990's as long a the air filter is clean and in place. Most get ruined with Bubba installing an over oiled K&N filter upstream. Odd how that modification is rarely mentioned.
Manifold leaks only occur on gasoline engines ?
I can purchase an entire complete long block DI gas engine for the price of a set of diesel common rail injectors and glow plugs.
Coil packs are reliable . Certainly simple to replace at home on the rare occasion they fail. They outlast glow plugs for certain.
How and why do airplanes fly reliably with high output gasoline engines instead of diesel. If diesel is so superior and gasoline unreliable .
   / Any news on gas engine CUTS? #148
Amazing how you so conveniently missed posting the rpm, torque and HP of the 4020 gas and diesel.
Why is it such a surprise to you and something for you to post
when I have already told you how many times how lousy the carburated gasoline engine was in the days of points distributers and when diesel 3/4 the price per gallon of gasoline. That was 50 years ago. Is this still current news to you?
Take a look on the wall, the calendar says 2015. Diesel has cost more per btu than gasoline since 2006 when ULSD was introduced. The tractors of today have Tier IV emissions equipment that you paid for up front and will pay to service after warranty runs out.
Today in light duty applications the DI gas is lower cost to purchase than diesel and has lower fuel operating costs. Cost to service that emissions equipment will cost less after warrenty expires on the simpler gas engine.
What are you talking about? I DID post the horsepower and RPM of the two engines. :confused2:
Again, you are the one bringing up 50 year old engines....not me. I've repeatedly said I'm only talking about the newest versions of both types of engines, and you keep bringing up old iron.
Yes, diesel has cost more than gasoline since ULSD was introduced, and when the costs incurred by the refineries are paid off, the price of diesel will drop back lower than the cost of gasoline....just like it has in the rest of the world. See, this has already happened in the rest of the world, but you refuse to accept what has happened everywhere else will happen here. Reality check....it's largely the same companies involved, so what happened in Europe, will happen here, and it's going to happen pretty soon....the price of diesel and gas has been getting closer for the last two years. In my field we call that a "clue."
The emissions equipment on a Tier IV tractor is ridiculously simple compared to the systems on gas automobiles right now. Why don't you talk about the requirement to eventually replace catalytic converters, and other expensive components that almost always fail after warranty periods expire?
   / Any news on gas engine CUTS? #149
The traditional diesel was by default a low rpm engine due to the short duration cam timing. Otherwise it would not start due to low cylinder pressure and thus low cylinder temperature.
Short cam timing is fine for 1000-2200rpm operation but it falls flat on it's face at higher rpms.
The gasoline engine can have the cam ground for more duration and improved airflow, this power at higher rpms.
Of course now with double over head cams with independent timing on both the intake and exhaust cams. The torque curve is now flattened instead of a sharp peak.
The gasser and even the diesel at part load ****** the intake cam so some of the combustion chamber air is pushed out. It gives a gasser a 3 or 4 to 1 compression ratio for less pumping and heating losses. Yet maintains the 12 to 1 expansion ratio on the power stroke.
The diesel when "throttled" with reduced intake charge improves it's part throttle thermal efficiency by not pumping unused cold air through the engine.
The diesel and gasser both benefit from wider power bands. Where do you think both engines gained the low speed torque and high rpm HP? The fiat diesel in the Dodge , Cruze and Canyon revs to 3800rpm to make peak HP.
Having actual flame and combustion with 90degrees crank angle is a waste of fuel and just adds heat to the cooling system through the cylinder walls.
The most effective use of fuel is by having peak combustion chamber pressure at and just after TDC. Why do you think spark advance is used ahead of TDC ? Back the timing off 20 degrees on any gas or diesel and the engine will loose power.
Depending on compression ratio, combustion chamber shape and fuel.flame propagation in a combustion chamber varies from 33 to 82ft per second . Hence the need to have combustion take place when the combustion chamber is smallest.
Hmmm....with all of those things in favor of the DI gasser, I'm confused about one thing. How is it possible that the Chevy Cruze you mentioned gets 8mpg less on the highway, has 13hp less, and 116lb/ft less torque? That's a typical light-duty cycle that the EPA puts them through, so the DI gasser should be way better than that diesel, but it's not. Funny....
   / Any news on gas engine CUTS? #150
The DI gas chosen for the vehicle is a smaller , lower output engine than the diesel. How is that a mystery, a point or concern? We are talking the same cruze Delta II chassis with gas vs Diesel engine .
The point is which are skirting is the gas costs less per mile . The gas car costs less to purchase than the diesel car. The Diesel was cost more to service in the future . Last Cat Converter I priced was $169 for a Terrain.
The V8 gas engine in the Camero makes more power than a Duramax Diesel, so what.
You are stuck thinking of a Gas engine in a 300HP field tractor performing heavy tillage. Not the case.The DI gas is for the light duty under 50HP CUT, boats, ATV, RTV, lawn equipment , light highway vehicles etc.
Status
1967 Minneapolis- Moline M670 (A50514)
1967 Minneapolis-...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
2020 KUBOTA RTV...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
John Deere Disk Chisel (A50515)
John Deere Disk...
