Any news on gas engine CUTS?
Status
Not open for further replies.
/ Any news on gas engine CUTS? #101
I've already stated why diesel has cost more than gasoline for the last 8 years. When the refineries pay off all those costs associated with implementing ULSD, the price of diesel should drop below gasoline again...just like it has in the rest of the world. Don't bother saying that once they set the prices higher, they will never come down, because I saw gasoline for $1.61/Gal the other day....hasn't been that low in many years.
I never said there was a difference in HP required to move either Cruz down the road. I simply said the diesel model performs better, and if people wanted that performance, they could buy it.
I never said anything about Uncle Bubba on his CUT. You don't know anything about how other people run their machines, so basing your argument off of that is pretty weak. Some, many, folks run their tractors at rated power the whole time they operate them. No, they won't put the hours on them that a loader in a rock quarry will, but that isn't the point. Run a similar size, power, weight gasser CUT the same way, and it's not going to stand up to it, or have as good of fuel economy as the diesel....period.
I said the costs to operate the diesel Cruz will vary with the price of fuel. It gets better MPG than the gasser, and when the price of diesel drops back below that of gas, there won't be a need to discuss any of this any longer.
Your entire argument centers around one thing...that diesel costs are artificially high right now. When that changes, there really won't be much to discuss about which system has the lowest operating costs over time.
I do find it funny that people claim higher maintenance costs on diesel tractors...most folks run them for many, many years with absolutely nothing required other than filters and fluids.
The conversation IS about the light diesel market in CUT and light highway vehicles.
Still no response form you about the extra cost of the diesel option.
Still no response from you about the cost of keeping a Tier IV diesel operating after warranty runs out.
Why do you keep bringing up diesel vs gasoline 20,30,40,50 years ago? Those non emission diesel engines, those carburated gasoline engines and the diesel vs gasoline prices are all long in the past never to return. Talking 2015 here.
Run the CUT on a DI gasser with the cheaper fuel per BTU vs diesel. The gasser is going to come out ahead with lower fuel costs, lower purchase price and lower service costs.
The DI gas with adjustable cam timing at part load drops the effective compression ratio to 3 or 4 to 1 but still keep the expansion ratio of up to 12 to 1. No un-used air being pumped through the combustion chamber as the diesel does at part load, cooling the combustion process and dropping the combustion chamber pressure. Power and efficiency on the crankshaft is the pressure difference between the compression stroke and the power stroke..
Ever notice the price of an ATV or RTV increases with the diesel option over gasoline version in the light duty market? Why is the gasoline engine cheaper and the diesle more $$$?
As long as HD operators are forced to use diesel. The price of ULSD won't drop below gasoline. The oil companies don't mid selling over priced ULSD to light duty operators if they will pay for it. Cause I'm gettin me self a diesel by gum cus thar better.
/ Any news on gas engine CUTS? #102
Who is talking about some old M with points and a carb ? The conversation is about the cost and practicality of a DI gasser for light duty use for putting around use in a CUT. Vs the cost of gasoline -diesel fuel , the tier IV emission equipment and future emissions equipment service at the dealership.
Do you take your M to the dealer for new points ?
A direct injected gas engine is going to cost just as much if not more than a diesel powerplant, not including tons of fragile electronics that do not belong on a tractor.
/ Any news on gas engine CUTS? #103
I have a GDI engine in my 2013 Impala. Its cheap. I will agree about fragile electronics, though. And those are expensive. For example, ours is a flex fuel engine. We got warnings about water in the fuel, but there wasn't any. There is a sensor that detects the amount of ethanol in the fuel. As you can imagine, if its running on gas with 10% ethanol and you dump in 6 gallons of e85, your percentage of ethanol changes to somewhere X% higher than 10% but less than 85% ethanol. That little sensor is the magic box in an e85 engine. It has to tell the computer the amount of ethanol so the computer can adjust the air-fuel mixture, timing, etc.... in the fly! Little magic box is $600 to replace + labor. It was under warranty. If it goes out again after warranty, I found aftermarket for $150. But that's just one little thing to go wrong out of many on a modern engine. I'm pretty sure the new diesels will have just as many magic boxes to monitor and control various aspects of the engine's systems.
/ Any news on gas engine CUTS? #104
Google diesel vs Otto cycle. You can skip the calculations and go through the graphs. And the law hasn't changed - ftorque = force times lever arm. Where an Otto cycle engine has peak force the lever arm is zero so at infinite combustion pressure torque is still zero. Diesel cycle maintains that force throughout the first 90 degrees of crank throw so where a gas engine falls on its butt, the diesel is still grunting. And it's why Ram is advertising how it whoops Ford's Eco-boost and why Motor Trend gave its Truck of the year to somebody other than the new Ford - because Ford's changes were made to improve fuel economy and it still loses to a diesel.
/ Any news on gas engine CUTS? #105
I have a GDI engine in my 2013 Impala..
How do you like the Impala? Other than the fuel moisture sensor
Edit,
Was thinking the new model came out in 2013. Looks like it was 2014.
/ Any news on gas engine CUTS? #106
Wrong (again)....you're the one adding in the whole "light duty" nonsense. We're talking about engines in tractors. Just because you think a CUT isn't worked hard doesn't make that reality.
I've already addressed all the things you say I haven't addressed, but I'm not surprised you've missed them...you're missing a lot.
I do find it funny you don't realize that a big part of why the diesel option for cars like the Cruz cost more is that so few of them are purchased. As Americans get more familiar with diesels, and buy more of the, that will lower the price per unit, but they have to start somewhere.
Still, if I was buying a Cruz tomorrow, I'd get the one with the diesel because it would perform better...even if it costs a bit more to operate. Some folks like performance and are willing to pay for it, even if a lower performing gasser that gets worse fuel economy is less expensive to purchase. I keep cars/trucks for a long, long time, so a couple of grand difference in purchase price doesn't matter to me if it's something I'll be happier with. If it saves me fuel costs in the long run, that's great...I'll find out in a couple hundred thousand miles.
I haven't brought up old diesel engines, or old gasser engines....only talked about the most modern of both. Remember how many times I've said the most efficient gassers max out at around 35% thermal efficiency and the most efficient diesels at 50% thermal efficiency? Those are the newest, not something old....but you missed that, right?
Your entire argument revolves around one thing you can't change....right now diesel costs more than gas In fact, I noted the station I passed tonight had regular gas at $2.11 and diesel at $2.69, since you asked about actual prices. That price reversal only happened when refineries were forced to spend a whole bunch of money to convert to ULSD. That cash outlay will be paid off before long, and diesel will go back to being less expensive than gasoline, just like it has in the rest of the world.
HD operators aren't "forced" to used diesel, they use it because it's the best tool for the job. Further, in the rest of the world the price of ULSD is lower than that of gasoline because they've already paid off the expenses required to make that change (years ago in most of the world). We're not any different, just a few years behind them. Again, you're arguing that they won't lower the price because they don't have to, but we've seen that isn't the case with the recent huge drops in the price of gasoline...and it's the same companies involved. By your theory, we'd still be paying $3.74/gal for gasoline, but we're not....bad theory it seems.
It's actually pretty funny watching you try to talk about how superior gas engines are, but you can't change the mechanics of when the pressure peaks relative to the crankshaft position, and it doesn't favor gassers. Nothing you do to a gas engine will change that. Sure, you can put a gasser in a tractor, and you'll have to make it a really big one to even come close to what a far smaller diesel will do when it comes to actual work, but that will kill any fuel economy savings you were trying to take advantage of.
If tractor manufacturers could make a case for making more money by building gasser CUTS or SCUTS they would have already done so....hasn't happened, and isn't likely to do so. You really don't think they studied the concept when faced with increasingly difficult emissions standards??? Nah, there's NO way that would have ever crossed their minds. :confused2:
/ Any news on gas engine CUTS? #107
This has been an interesting story with lots of theoretical conjecture and I will admit I have very little knowledge of how emission standards have affected tractors but I know first hand it was not good for the trucking industry. I'm sure things will get better but when emission standards for cars were introduced in the 70's it took well into the 90's for cars to finally be good again but now they rock you have 4cylinder mustangs that out perform 428 cobra jets. So hopefully the future will be better for diesel. I'll admit also I love diesel engines the first time I heard a Cummins KTA running wide open tickled me in a way no woman ever could and I totally understand the cool factor of wanting a diesel tractor to do yard work I just wish companies would respond to changing facts and offer alternatives to diesel fuel.
One final thought as the son and wife of an engineers never argue with them its like wresting with pigs.
/ Any news on gas engine CUTS? #108
Yet Dodge has cuts the payload on the trucks equipped with the diesel by 200+ pounds and raises the max trailer weight... Not quite sure how that works.
Aaron Z
/ Any news on gas engine CUTS? #109
Aaron Z
Just a guess, but the diesel combo could easily weigh 200lbs more, so they reduced the payload that same amount. The trailer weight can go up because of the increased pulling ability, but I'd guess they kept the trailer tongue weight limit the same.
/ Any news on gas engine CUTS? #110
So what about the power and torque. The average driver doesn't even know. Both vehicles accelerate up to highway speeds without being floored.
$300 a year for fuel. I don't hear you being glad about the extra cost of the diesel option. Nary a peep either about paying the dealership to work on that emission diesel.
I think you would notice if you drove one of my cars. My 2002 VW TDI is 90HP stock. I can set the cruise control on 70MPH and the speedo needle will not budge going up Sandstone Mountain on I-64 in WV. It's a 5 speed and I don't have to gear down. No other vehicle I've driven on that mountain will do that.
As said before, Diesel makes its power at the low end. My car redlines at 4,500 RPM while a Mazda Rx8 is just coming alive at 9,000 RPM.
$300 extra in fuel? I think your cost per BTU measure is more theoretical. I use actual cost per mile to do my comparisons. None of my gassers can do 50+MPG so operating my TDI's costs several cents per mile less than my gassers. Diesel fuel price would have to go way, way up before gas was less per mile. Yes, I could drive a Prius or something to come close or maybe even do a tiny better in some cases but then other factors start to come into play .... show me a Prius that is as old as my 2002 or has as many miles on it that still gets the MPG's it did when it left the lot (I know there are "Consumer Reports" that say they are reliable 10+ years old but personal experience says different). My car is fun to drive (way more so than a Prius), very safe crash rating (it is not a light car at all). Bottom line is it delivers in more areas than just MPG so it is my 'personal preference' I'm voicing here.
Diesel is the Apocalypse engine. WWII the Army used multi-fuel engines. I can run my stuff off D2, D1+D2, BioDiesel, SVO, WVO etc. As has also been mentioned, today's gasoline just doesn't have the shelf life (even with additives) of diesel straight from the pump much less diesel with added additives. Most on here have tanks where they store large quantities of fuel long term. Sits for years ... no problem. I don't think gas can even come close to doing that anymore. When the power goes out and you need to run a big generator head via tractor PTO these fuel stores matter.
The engines you are describing are basically copies of what's in autos/trucks today. Would require ECU, MAF, O2 sensors, EGR, Fuel Temp sensor's, Gas vapor reclaiming systems, and on and on, OBD2 to trouble shoot etc.. No way I want all that stuff on my tractor. I balked at Tier IV, no way would I go more complicated and that's what we're talking about here. I only have so much life left ... I'll bide my time with non DPF diesels. I want something that is reliable that I can work on myself and make it last. I'll keep my simple diesel engines.
/ Any news on gas engine CUTS? #111
I'm really not buying this "Diesel costs more to operate" line of thinking.
Again, every case is different but for me all I really have to change on my car is the timing belt every 100K miles. I also change everything that touches the belt (which dealers won't do). I don't have to buy a bunch of O2 sensors that wear out and make the MPG's go down, plugs or plug wires that also lose efficiency etc. My factory oil change interval is 10K miles. I use synthetic oil that is more expensive but today's gassers use it too to game EPA/MPG and no gasser that I'm aware of will let you do a 10K OCI ... so oil changes are a wash if not cheaper for the diesel in some cases. I have bypass oil filters on all my TDI's and on my 2002 I can do extended OCI's that run well over 10K miles. Plus, all that needs to happen to the car I do myself (I have the manuals & tools). My car has not been back to the dealer since it was new. TDIClub and VCDS on a laptop is all I need to keep it going and that's the way I like to roll.
Now if you are the type that takes your car back to the dealer where you bought it for service ... you are going to get hurt no matter if it is gas or diesel.
/ Any news on gas engine CUTS? #113
What ? No electronics on a Tier IV farm, industrial or highway diesel ? A DI gasser in a ATV, RTV , pickup or Chevy Cruze costs how many thousand less than the diesel version? Is there glow plugs, a particulate filter , urea injection or a two battery starting system on a gasser? I already stated all those facts in a previous post, did you forget?
/ Any news on gas engine CUTS? #114
I know someone who has a first generation Prius (he bought it the first year they came here, so a 2004?) with over 250k miles (probably pushing 300k miles by now). It has had 2 sets of brakes, regular oil changes and a couple of recalls (something related to the steering column IIRC).
It still gets high 40s on the highway and better around town.
Aaron Z
/ Any news on gas engine CUTS? #115
Some electronics yes. There are a bunch of ways to meet Tier IV. Does not meant a full blown ECU with all the associated sensors.
The diesel "premium" is mostly marketing hog wash. Dealers know people will pay more money for a vehicle that gets better MPG because the people that pick them over the gas model do so for a reason so they capitalize on it.
Plus it's a supply and demand thing. I can sell my car as old as it is and with as many miles as it has for quite a bit too .... again supply and demand.
None of my diesels have all that stuff you mentioned and I won't have any in the future if I can help it.
/ Any news on gas engine CUTS? #116
Aaron Z
There are some, I acknowledge that. But I've also seen plenty with major problems. I haven't seen many keep them real long. They came out in 2001, 2002 if memory serves me right.
The MPG on my 2002 increased from new. The guru's say they aren't broke in developing their peak compression until they hit around 60K miles. I've had two now and have observed the MPGs increasing so I believe it.
/ Any news on gas engine CUTS? #117
Google diesel vs Otto cycle. You can skip the calculations and go through the graphs. And the law hasn't changed - ftorque = force times lever arm. Where an Otto cycle engine has peak force the lever arm is zero so at infinite combustion pressure torque is still zero. Diesel cycle maintains that force throughout the first 90 degrees of crank throw so where a gas engine falls on its butt, the diesel is still grunting. And it's why Ram is advertising how it whoops Ford's Eco-boost and why Motoro Trend gave its Truck of the year to somebody other than the new Ford - because Ford's changes were made to improve fuel economy and it still loses to a diesel.
It's not combustion occurring at 90degrees crank angle that makes torque. It's the higher peak combustion chamber pressure over compression pressure that makes torque.
If you would compare apples to apples with a 4020 gas and a 4020 diesel . Where are the differces in rpm, torque and HP? There is little to none, in fact the gasser may perform slightly better.
The traditional diesel was by default a low rpm engine due to the short duration cam timing. Otherwise it would not start due to low cylinder pressure and thus low cylinder temperature.
Short cam timing is fine for 1000-2200rpm operation but it falls flat on it's face at higher rpms.
The gasoline engine can have the cam ground for more duration and improved airflow, this power at higher rpms.
Of course now with double over head cams with independent timing on both the intake and exhaust cams. The torque curve is now flattened instead of a sharp peak.
The gasser and even the diesel at part load ****** the intake cam so some of the combustion chamber air is pushed out. It gives a gasser a 3 or 4 to 1 compression ratio for less pumping and heating losses. Yet maintains the 12 to 1 expansion ratio on the power stroke.
The diesel when "throttled" with reduced intake charge improves it's part throttle thermal efficiency by not pumping unused cold air through the engine.
The diesel and gasser both benefit from wider power bands. Where do you think both engines gained the low speed torque and high rpm HP? The fiat diesel in the Dodge , Cruze and Canyon revs to 3800rpm to make peak HP.
Having actual flame and combustion with 90degrees crank angle is a waste of fuel and just adds heat to the cooling system through the cylinder walls.
The most effective use of fuel is by having peak combustion chamber pressure at and just after TDC. Why do you think spark advance is used ahead of TDC ? Back the timing off 20 degrees on any gas or diesel and the engine will loose power.
Depending on compression ratio, combustion chamber shape and fuel.flame propagation in a combustion chamber varies from 33 to 82ft per second . Hence the need to have combustion take place when the combustion chamber is smallest.
/ Any news on gas engine CUTS? #118
... now that I'm at a real keyboard I'll elaborate a little more on the "Diesel Premium". Until very recently, there were 5 or so CARB states where vehicles like the VW TDI couldn't be sold new because they didn't meet the States emission requirements (I won't say what I call those states). So people in the states that could by them would get them and keep them for a year or two and sell them for as much or more than they paid for them to someone in a CARB state (used ones that had a certain mileage or age were allowed ... can't remember the details) that needed something that got 50MPG. There were a few years where no new model TDI was offered which further fueled the demand and Katrina hitting during that same time didn't help things much.
I cannot give any numbers on how much the "Premium" is from supply/demand and economy of scale. Maybe an auto mfr. is on here and can spill the beans. But again, because of our wonderful lawmakers, dealers were only allowed to import so many diesels (like 3-4% of gasser models). So dealers had quota's of that pool too. Example: I bought my 2006 in fall of 2005. Katrina was driving gas prices through the roof. I was activated in the states (Operation Noble Eagle) and I either had to stay on post or drive 1-1/2 hr one way to work (3+hrs a day). My vehicles at the time got in the mid 20's so it was killing me. Driving back and forth was on my own dime so I decided to buy a TDI. My dealer had two on the lot and people were basically fighting over them. In fact, as we were signing the papers, I saw a dealer take a family out for a test drive in the car I just bought!
There are some gassers that have this same problem too. You'll have the "sticker" price and then the "market" price. There are some vehicles due to their demand that will have a "market" price above the MSRP "sticker" price.
/ Any news on gas engine CUTS? #119
Un
Those " DI gasoline " electronics you dread are every bit as much or more abundant on the Tier IV diesel.
As for being able to burn anything. One could distill ethanol and operate a DI gas. For anybody pouring salvage fuel into a 30,000psi common rail injection diesel system. It's going to be finiky.
For light highway vehicles. I was never alarmed if it down shifted to climb a hill.
The diesel Cruze vs gas Cruze was quoted from official EPA tests which I trust more than here say evidence.
The same site with figures published before gasoline prices fell and diesel stayed high was $1200 a year to drive a diesel Golf and $1050 to drive a gas Golf.
Before even paying the cost of the Golf's diesel option. Where are you saving $ with diesel? Let's hope she never needs glow plugs or injectors past warranty .
/ Any news on gas engine CUTS? #120
Edit,
2011, 2012 and 2013 only came with one engine option, regardless of trim package. 3.6l aluminum V6 with variable valve timing, GDI, double overhead cam, 300hp @6500 rpm, 262ft lb torque around 5300rpm. 6sp tranny. It has just about the best power to weight ratio in its class. Goes in a straight line like a rocket up to 140+. That said, its a cheap plastic car with lousy brakes! :laughing:
I liked our 2000 Impala body style and interior much better. But this car is way quicker. Cheap, cheap fun.
The 2014 is a much different animal, very nice interior and actually a nice car. What's kind of confusing is you can still get the 2013 body style until 2015, its called the something like the fleet model for cops and cabs, etc...
Status
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2014 Dodge Grand Caravan Van (A61569)
2014 Dodge Grand...
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
KUBOTA KX057-4 EXCAVATOR (A62129)
KUBOTA KX057-4...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
1990 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 2J4FY29T5LJ516997 (A61165)
1990 Jeep Wrangler...
