any mfg make and affordable rider with rear lift?
   / any mfg make and affordable rider with rear lift? #1
DVR
Columbia, SC
Kubota MX5400 cab, Kubota L3560LE cab, Kubota L3301
I need an affordable riding mower that is capable of lifting and moving my trailers. I use a drawbar in my Kubota now but really would like a mower with the ability to handle this task. prefer 2wd and gas power for costs sake.
I can move the items in question with my snapper but I have to lift them to the hitch ball. I have some issues with my back so that option does not work so well any longer.
thanks in advance.
   / any mfg make and affordable rider with rear lift? #2
What kind of trailers are you talking about? Are they on concrete or in dirt/grass? I think something like they pull small planes or boats around with might work, it is just an engine powered dolly with handle steering controls. I'll see if I can find a link.
6 1/2 Horse Power Gas Powered Do
Something like this might work, kind of pricey though. Good luck with your search.
   / any mfg make and affordable rider with rear lift? #3
That really depends upon your trailer sizes and their accompanying weight issues. Sears Craftsman has an electronic lift, as an accessory item for their larger Lawn & Garden Tractors - I believe it to be the same one sold by Johnny Buckets. You can find this lift @ www.Sears.com - then go to Lawn & Garden; tractor accessory items and "Voila." :D
Or you can go to www.JohnnyProducts.com and check-out their version of the same thing. The unit at Sears is presently on sale - regular $399 for $359; the Johnny Bucket version generally sells for $459. I believe that Johnny Buckets may even make this unit for Sears, as they appear to be very close in appearance. :eek:
To my knowledge no one utilizes on of these special lifts on their Lawn & Garden tractors as "standard equipment." Whether one of these will work for your particular situation is totally up to you. ;)
Regards,
Chuck Herron
thanks for the replies.
my movement is on grass and concrete. my snapper rider moves them w/o much of a problem as long as I lift them to the front mounted hitch ball.
i move a 18ft mud boat, a 17ft center console boat, a 16ft flatbed, a 14ft jon boat and a 5x10 utility trailer. 3 of those i cannot move by hand at all.
the johhny lift use a 12v motor and actuator and I actually have one (actuator) just like it.
I can fab a similar frame but the unit is too large and would cause problems with any bagger.
i think i knew the answer when I posted. no one makes what i want. i will have to go to a small garder tractor like a kubota bx model I assume.
seems like a great option for the mfg's to offer? i would pay an extra $500+ for a mower equipped with such.
thanks again.
   / any mfg make and affordable rider with rear lift? #5
Well you can always buy an older small Kubota or other manufacture.
I have a little 2WD 15hp Mitsubishi that I use for my trailer moving, bush hogging, tilling and water carrying duties.
These little tractors are just easy to to use.
Looks like you should have kept the B7510 like I should have kept my B7500:(
   / any mfg make and affordable rider with rear lift? #6
Look at the grey market little Jap tractors.
   / any mfg make and affordable rider with rear lift? #7
thanks again.
Do you have a tongue jack for each? With that, there should be minumal, if any lifting at all. I have a tongue jack on two of my trailers, boat and the 16' utility.
West Marine: 1000 lb. Swivel Jack Product Display
   / any mfg make and affordable rider with rear lift? #8
I was thinking the same thing as CRBR, and they make one with an electric motor, if the cranking is also a problem. Or maybe you use a small electric jack that you would just move from trailer to trailer to lift the tongue so you could get the hitch ball under it.
   / any mfg make and affordable rider with rear lift? #9
Older Simplicity had this feature and are 10 times that tractor most of todays are.
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A55218)
2012 New Holland...
20" Sea Container (A47384)
20" Sea Container...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
Electric Mobility Scooter (A51694)
Electric Mobility...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
