any mfg make and affordable rider with rear lift?
   / any mfg make and affordable rider with rear lift? #1
DVR
Columbia, SC
Kubota MX5400 cab, Kubota L3560LE cab, Kubota L3301
I need an affordable riding mower that is capable of lifting and moving my trailers. I use a drawbar in my Kubota now but really would like a mower with the ability to handle this task. prefer 2wd and gas power for costs sake.
I can move the items in question with my snapper but I have to lift them to the hitch ball. I have some issues with my back so that option does not work so well any longer.
thanks in advance.
   / any mfg make and affordable rider with rear lift? #2
What kind of trailers are you talking about? Are they on concrete or in dirt/grass? I think something like they pull small planes or boats around with might work, it is just an engine powered dolly with handle steering controls. I'll see if I can find a link.
6 1/2 Horse Power Gas Powered Do
Something like this might work, kind of pricey though. Good luck with your search.
   / any mfg make and affordable rider with rear lift? #3
That really depends upon your trailer sizes and their accompanying weight issues. Sears Craftsman has an electronic lift, as an accessory item for their larger Lawn & Garden Tractors - I believe it to be the same one sold by Johnny Buckets. You can find this lift @ www.Sears.com - then go to Lawn & Garden; tractor accessory items and "Voila." :D
Or you can go to www.JohnnyProducts.com and check-out their version of the same thing. The unit at Sears is presently on sale - regular $399 for $359; the Johnny Bucket version generally sells for $459. I believe that Johnny Buckets may even make this unit for Sears, as they appear to be very close in appearance. :eek:
To my knowledge no one utilizes on of these special lifts on their Lawn & Garden tractors as "standard equipment." Whether one of these will work for your particular situation is totally up to you. ;)
Regards,
Chuck Herron
thanks for the replies.
my movement is on grass and concrete. my snapper rider moves them w/o much of a problem as long as I lift them to the front mounted hitch ball.
i move a 18ft mud boat, a 17ft center console boat, a 16ft flatbed, a 14ft jon boat and a 5x10 utility trailer. 3 of those i cannot move by hand at all.
the johhny lift use a 12v motor and actuator and I actually have one (actuator) just like it.
I can fab a similar frame but the unit is too large and would cause problems with any bagger.
i think i knew the answer when I posted. no one makes what i want. i will have to go to a small garder tractor like a kubota bx model I assume.
seems like a great option for the mfg's to offer? i would pay an extra $500+ for a mower equipped with such.
thanks again.
   / any mfg make and affordable rider with rear lift? #5
Well you can always buy an older small Kubota or other manufacture.
I have a little 2WD 15hp Mitsubishi that I use for my trailer moving, bush hogging, tilling and water carrying duties.
These little tractors are just easy to to use.
Looks like you should have kept the B7510 like I should have kept my B7500:(
   / any mfg make and affordable rider with rear lift? #6
Look at the grey market little Jap tractors.
   / any mfg make and affordable rider with rear lift? #7
thanks again.
Do you have a tongue jack for each? With that, there should be minumal, if any lifting at all. I have a tongue jack on two of my trailers, boat and the 16' utility.
West Marine: 1000 lb. Swivel Jack Product Display
   / any mfg make and affordable rider with rear lift? #8
I was thinking the same thing as CRBR, and they make one with an electric motor, if the cranking is also a problem. Or maybe you use a small electric jack that you would just move from trailer to trailer to lift the tongue so you could get the hitch ball under it.
   / any mfg make and affordable rider with rear lift? #9
Older Simplicity had this feature and are 10 times that tractor most of todays are.
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55301)
2012 KINZE FLAT...
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
