Any JD sickle bar owners here??
   / Any JD sickle bar owners here?? #1
outdoorstom
Waddington, NY (waaaay up north)
Kubota L5240
I posted this in the "attachments" area too, but thought I might have better luck here since this is a Kubota specific question. I have found a JD #39 sickle mower to buy, but want to make sure it will fit my L5240 before driving the hour and a half to get it. Does anyone know for sure, one way or the other? Thanks!
   / Any JD sickle bar owners here?? #2
Most sickle mowers are cat 1 hitch systems so you should be fine. Length of PTO shaft might not be right but most dealers can cut you new length shafts within a reasonable time and at a fair price.
I'm not sure of how that mower is equipped but I sure do like the belt drives instead of the older wooden pitmans that break when hitting something solid.
Thanks for the response Art. This is a Cat II hitch. I plan on calling my dealer today and asking him if this will work. I'm hopeful since I've been having a hard time finding a mower in this area.:(
   / Any JD sickle bar owners here?? #4
I have a JD #39. I don't know, I think you asked in another forum the difference between a couple models with "N" or somthing.
I use mine on a Montana 4340C I have no hook up issues or PTO issues, it is both belt and Pittman stick, carefull with the pittman it can break easily!
I really like mine and believe you will too. I think you said $300.00? That seems to be fair enough!
Yes, I read about the "N" & "W" differences, so I wondered if they came into play here. I spoke with my dealer today and he thinks it will work. I plan on picking it up Sunday. Worse case, if it doesn't fit I'll sell it.
   / Any JD sickle bar owners here?? #6
Mine use's the the top link as well as the lift arms. However it is a little different than most 3 pt hook ups. If I can describe it, when you back to it your lift arms go over top of a frame to the point where you put in the pins, then there is a u type bracket that goes threw a plate and around the lift arms, one on each side. Works fine!!
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A57453)
2016 Hino 195h...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
