Any JD sickle bar owners here??
   / Any JD sickle bar owners here?? #1
outdoorstom
Waddington, NY (waaaay up north)
Kubota L5240
I posted this in the "attachments" area too, but thought I might have better luck here since this is a Kubota specific question. I have found a JD #39 sickle mower to buy, but want to make sure it will fit my L5240 before driving the hour and a half to get it. Does anyone know for sure, one way or the other? Thanks!
   / Any JD sickle bar owners here?? #2
Most sickle mowers are cat 1 hitch systems so you should be fine. Length of PTO shaft might not be right but most dealers can cut you new length shafts within a reasonable time and at a fair price.
I'm not sure of how that mower is equipped but I sure do like the belt drives instead of the older wooden pitmans that break when hitting something solid.
Thanks for the response Art. This is a Cat II hitch. I plan on calling my dealer today and asking him if this will work. I'm hopeful since I've been having a hard time finding a mower in this area.:(
   / Any JD sickle bar owners here?? #4
I have a JD #39. I don't know, I think you asked in another forum the difference between a couple models with "N" or somthing.
I use mine on a Montana 4340C I have no hook up issues or PTO issues, it is both belt and Pittman stick, carefull with the pittman it can break easily!
I really like mine and believe you will too. I think you said $300.00? That seems to be fair enough!
Yes, I read about the "N" & "W" differences, so I wondered if they came into play here. I spoke with my dealer today and he thinks it will work. I plan on picking it up Sunday. Worse case, if it doesn't fit I'll sell it.
   / Any JD sickle bar owners here?? #6
Mine use's the the top link as well as the lift arms. However it is a little different than most 3 pt hook ups. If I can describe it, when you back to it your lift arms go over top of a frame to the point where you put in the pins, then there is a u type bracket that goes threw a plate and around the lift arms, one on each side. Works fine!!
New/Unused Single Portable Toilet (A57453)
New/Unused Single...
102 (A56857)
102 (A56857)
2019 8'x25' Homemade Trailer (A57148)
2019 8'x25'...
CAT930K (A58214)
CAT930K (A58214)
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
