Tires Any disadvantage to using smaller diameter tires
   / Any disadvantage to using smaller diameter tires
Thanks for all the inputs. They are greatly appreciated.
   / Any disadvantage to using smaller diameter tires #12
When I was looking into buying a tractor I hired a 20hp Kubota to see if it would be sufficent for my needs. Turns out it didn't have the required grunt to pull a RC up a minor hill using the hydrostatic so it was out but it also failed another test. I have loads of Wombats on my place and they dig holes about the same size as the little Kubota's front wheel. The front wheel dropped into the wombat hole and in a matter of nano-seconds the tractor was on its side. Thank god for the loader or else it would have rolled completely.
Now that was a disadvantage to smaller wheels and not so much the tyres. But I like the story so thought I'd share it anyhow.
   / Any disadvantage to using smaller diameter tires #13
Stephen.
I would think you would almost need a crawler in wombat country. An other point of interest Just don't hit them (wombats)at high speed on the road in your car its like running into a 1/2 55gal drum filled with concrete. /forums/images/graemlins/blush.gif
   / Any disadvantage to using smaller diameter tires #14
A tractor sitting 2" lower will have a very small, marginally noticable difference in the center of gravity.
You will lose ground clearance, use of some belly mowers, get a worse ride, much worse tractoion, lower load rating (weight you can load on the tractor), the proof-meter will be off for mph, unless someone matches this up proper you will have a different ratio between your front & rear tires & that will be hard on your 4wd transfer case, and a host of other negatives mentioned here.
A taller tire, within reason, is _always_ a positive thing. A lower tire is a negative, unless you absolutely must have a lower tractor for some real reason.
Now, fatter or skinnier tire is a trickier question. In some cases, like mud or snow, a tall skinny tire might have far more traction than a regular fat tire. In any case, the shorter tire will always have poorer traction.
Taller is better for 99% of applications. You can't really compensate by getting a shorter but fatter tire - it don't work that way.
In snow or mud, you need to sink through the soft stuff & get good footing on the harder sub-soil layer. A fat short tire won't make it, you will be hung up. A tall skiny tire will offer less resistance to the mud & will dig you out on the subsoil layer. While a tall fat tire will have more suction & mud resistance, but probably will get to the hard subsoil layer & should get you out.
This same principle applies, in miniture, to any heavy pulling situation on regular dry dirt. Us farmers are turning to much taller, skinnier tires on our combines & tractors to pull better.
I think shorter tires is a bad direction to go unless you understand what you are giving up & have a good need for the shorter tires.
--->Paul
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
*Selling at Royal Auction Tampa, FL Location* Runs and drives. Needs jump. 1987 hrs. (A59228)
*Selling at Royal...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
