Antifreeze
/ Antifreeze #1
RebelPride
upstate south carolina
850 john deere
I just completed the 200 hour service on my JD 850, but have not done a coolant flush and refill. I was wondering what type of antifreeze to use? Should i just use the same same kind i use in my vehicles? It does not get extremely cold here in winters, and i usually use a 50/50 antifreeze water mix in my vehicles, would this mixture also be ok in my tractor?
Thanks
/ Antifreeze #2
That's the mix I used in the widow's JD a couple years ago when I changed it.
The 50/50 mix is generally recommended because it's close to the lowest freeze point and highest rise in boiling point. You don't want pure water, freezes at 32 F but expands a bunch when frozen. Pure ethylene glycol freezes at about 4 F (but doesn't expand like water).
Put the 2 together in the right blend (somewhere near 50/50), and the freeze point drops to -70 F and boiling point rises to around 240 F. Ain't chemistry great?
Ralph
Retired chemical engineer
/ Antifreeze #3
Be sure and use antifreeze made for diesel engines.
There is plenty of reading on this in general forums, oil ect.
Might look there.
/ Antifreeze #4
Rick
Here is a link to a TBN thread on Antifreeze in tractors. Click here.
Here is a copy of <font color="green"> JD's </font> site on Anti Freeze.
Coolants
John Deere Cool-Gard™ Antifreeze/Summer Coolant gives you ultimate year-round protection for your cooling system
Are you using the right antifreeze/summer coolant?
Not if you haven’t matched the right product to the performance demands of your equipment! Heavy-duty engine cooling systems need special care and protection year-round. Unfortunately, many owners don’t service their equipment’s cooling systems regularly. Or if they do, they may believe that any automotive antifreeze or summer coolant will do the job.
But that’s not true! While most antifreeze/ coolants will prevent freeze-up or boil-over, they don’t perform adequately in heavy-duty machines. They can’t provide the balanced protection your cooling system needs to operate efficiently under extreme pressures and temperatures, and with high volumes of flowing engine coolant. The right engine coolant will protect internal surfaces and components, as well as provide freeze protection and heat transfer properties. Water only is never recommended.
Why choose Cool-Gard over another coolant?
John Deere has specifically engineered a fully formulated, heavy-duty antifreeze/summer coolant to match the performance requirements of our equipment. This is the same antifreeze used in new John Deere machines. In fact, our engineers highly recommend it for use in all heavy-duty and light-duty diesel and gasoline engines, including automobiles.
John Deere Cool-Gard is available in two forms — concentrate, which must be mixed with water for proper freeze protection, and pre-mix (ready to use), which contains 50 percent demineralized water and has a freeze point of -34 ºF. (-37 ºC). Both contain coolant conditioner, anti-corrosion additives, and anti-foaming agents to guard against liner pitting, rust, corrosion, and scaling. Both have a service life of 5 years/5,000 hours.
/ Antifreeze #5
I like the JD premix then I don't have to worry about getting the correct amount mixed and I can add a little if my machines get low. It is only available in the 50:50 mix.
/ Antifreeze #6
Yeah, Nick that makes it nice for adding as needed..
How've you been? I hadn't noticed any post from our end lately (course I ain't the smartest bump on the log, now...) Are you back at school? What year?
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2007 CATERPILLAR 277B TURBO SKID STEER (A65056)
2007 CATERPILLAR...
2023 Dodge Durango AWD SUV (A66738)
2023 Dodge Durango...
