Antifreeze
/ Antifreeze #1
sacsr
Kinston, NC
Yanmar 187D Terramite T5C Bush Hog D4-10
I tried to search the forums but could not find this answer. I am needing to put some antifreeze in my over flow bottle. I have on hand 2 types of prestone antifreeze....1 that is a 50/50 solution for "all makes of vehicles" and the other is a full strength antifreeze again for "all makes"....is this okay to put in my yanmar???
Thanks,
Scott
/ Antifreeze #2
Thanks,
Scott
yep. If you dont have a water pump, the maximum ratio you want according to hoye and others is 20% antifreeze. If you have a pump you can mix those that you have at what ever dillution you want, as long as it gives you freeze protection for you r area
/ Antifreeze #3
It sounds like what you have is the new universal type so yes it is ok just like it says you can use it no problem.
The old green/yellow ethylene glycol type is not recommended to be mixed with newer cars with long life coolant like dexcool and other manufactures pet brand names there are 8 or 9 different types now, universal is supposed to work in all fwtw.
/ Antifreeze #4
Thanks,
Scott
You need the stuff specially formulated for diesel engines.
/ Antifreeze #5
You can use any antifreeze, for diesels or not. I do the same, including on our 1987 Mercedes SDL and its got 261,000 miles on it and runs like a top.
/ Antifreeze #6
as stated use max of 25% coolant in a thermosyphon system(no water pump) and up to 50/50 with water pumped units. i prefer to use concentrates and mix them myself as the premixed ones i feel are stingy in the glycol department. i changed my coolant today(the coolant in the reservoir had no colour left and it came out of the block grey!) i mixed it in a bucket and filled it up and the reservoir with the same mix. i suggest you replace it all so you know it is all the same brew. i ran it hard nearly all day slashing and it never went over 100 deg C. and the ambient was in the high 20s C
/ Antifreeze
Thanks Guys...I appreciate the info....
PALLET OF AIR FILTERS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF AIR...
1988 Yamaha 200hp 2-Stroke Boat Motor (A66738)
1988 Yamaha 200hp...
2006 KENWORTH W900 (INOPERABLE) (A67714)
2006 KENWORTH W900...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
2017 Nissan Titan 4x4 Pickup Truck (A66736)
2017 Nissan Titan...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
