Antifreeze/Engine Coolant
/ Antifreeze/Engine Coolant
Not to answer for Richard...
Most of the newer automobile engines have alot of aluminum that requires this extra silicate that is detremental to diesel engine/radiator passages...{note clogging etc.}
For some reason, the off the shelf antifreeze in the stores is by far cheaper to buy then the pre-charge for diesels...{not that it should be? Supply/demand principle?}
On the same token, you can have one case of diesel oil for everything... /w3tcompact/icons/blush.gif {again more expensive...}
/ Antifreeze/Engine Coolant #22
Yea I agree with John you are talking about a completely different system that requires different coolant. Stick with the regular prestone etc. for the gas engines.
/ Antifreeze/Engine Coolant #24
The erosion is caused by a phenomenon known as 'jetting'. The bubbles collapse when they get hit by the pressure waves passing through the fluid in which they are suspended. The bubble doesn't burst as a balloon would - but instead it collapses asymetrically.
In laymans terms imagine a pretzel shape (the curly ones not the pretzel sticks). This is roughly what a collapsing bubble looks like in cross-section. One side of the bubble folds in on itself.
The result of the bubble collapsing in this way is that a fluid jet is rapidly expelled by the collapsing bubble. This is the fluid caught between the collapsing halves of the high pressure gas bubble. The fluid jet will typically achieve supersonic speeds (i.e. faster than the speed of sound in the fluid in which it is travelling). When the supersonic jet hits a solid surface you get a nice little shock-wave interaction that pits the solid surface.
This is the same principle that is used in HEAT (High Explosive Anti Tank) rounds - the principle of shaped charges. In the case of HEAT rounds you can use a copper shaped charge liner to penetrate armor-plate.
Fun stuff.
Patrick
/ Antifreeze/Engine Coolant #25
What does SCA mean.
RCH
/ Antifreeze/Engine Coolant #26
<font color=blue>What does SCA mean</font color=blue>
Here's what one company says about it (talking about Fords):
"Supplemental Coolant Additives (SCA's) are important to ensure long diesel engine life. Their primary function is to protect the cylinder wall from cavitation erosion (pitting). Secondarily, they bolster the anti-corrosion additives in antifreeze. The purpose of SCA is to prevent cavitation erosion of the cylinder lines. The additive concentration should be checked every 4 months to assure that it is properly maintained."
/ Antifreeze/Engine Coolant #27
John,
<font color=blue>... an "electrolysis type action" results... </font color=blue>
Can you provide further insight or references to this phenomenon? I would like to know more. Thanks in advance.
Al
/ Antifreeze/Engine Coolant #28
Patrick,
<font color=blue>The erosion is caused by a phenomenon known as 'jetting'. </font color=blue>
I would like to know more about this, can you provide a reference that explains this and the fluid properties that allow it to occur. Thanks in advance.
Al
/ Antifreeze/Engine Coolant #29
I'll hit two birds with one stone here ...
First note that John Miller's note refers to an "electrolysis like" action. This refers to a mechanism similar to spark erosion. It does not indicate that the pitting caused by cavitation is due to spark erosion - just that it produces similar results.
Second, with regard to my comments about erosion due to jetting ... I'll give a brief description, but you won't find much (if anything) in the public domain on it. You could try a search on 'bubble micro-jetting cavitation' to see what comes up but it won't be very much. The military is very familiar with this concept.
Basically, cavitation occurs at areas of low pressure within a liquid. The low-pressure allows microscopic bubbles to form of the vapor phase of the liquid.
When a shock-wave in the liquid impinges on these bubbles the bubble can collapse asymetrically. Not to trivialize, but the bubble first starts to look like a kidney shape as the shock-wave hits it - then as the shock-wave passes over/through it it starts to look more like a pac-man profile. The 'mouth' of the pacman would be at the opposite side to where the shock-wave hits the bubble first.
Now imagine what happens to the liquid caught in the 'pacman' shaped bubble's 'mouth'. The bubble collapse forces the liquid to accelerate to extremely high speeds - typically supersonic. This creates an effect known as jetting or micro-jetting (on this small scale).
The jet reaches extremely high speeds. When the bubble collapses in close proximity to the cylinder wall, the jet will impact the cylinder before it has lost any energy. The energy in the jet is such that it will hydrodynamically penetrate the material in the cylinder wall.
This is not melting or abrasion. The momentum of the jet is high enough that the target material simply flows away from the point of impact. This results (for a micro-jet) in a little pit on the target. Materials behave very differently under these high strain-rate / shock-wave conditions than they do normally. The effect is literally like aiming a high-pressure water-jet at a mud bank.
The end result looks similar to spark erosion, but under microscopic examination they look quite different. Spark erosion produces localized melting and other thermal effects. Micro-jetting does not.
This jetting mechanism is similar to that used for armor piercing munitions by the military - hence their interest.
Patrick
Many things are occurring at once within the cooling system… electrolysis is only one factor. Anytime you have a mixture of water and dissimilar metals, you have this chemical reaction called electrolysis and you have the start of a miniature battery
With the water flow throughout the cooling system, you have this turbulence causing erosion of the passages… and with the radiator and engine dissimilar metal particles suspended in the antifreeze and movement all combined produce the electrolysis effect.
Without the proper antifreeze and additives, you end up with corrosion of the internal cooling area along with cavitation, pitting, etching, jelling, clogging, and harmful deposits…
The bottom line… just like you change your oil in the engine on a regular basis to remove all the harmful impurities… you should change your antifreeze every 24-36 months for the same reason.
Changing engine oil and antifreeze on a routine schedule is the best and cheapest insurance you can give your tractor’s diesel engine for a long and happy life…
/ Antifreeze/Engine Coolant #31
Patrick and John,
Thanks for taking the time to enlighten me further. Pat is right, not much to be found in the public domain (excluding TBN /w3tcompact/icons/smile.gif) I have some failures in high speed centrifugal pumps where the pump housing has been breached in the area of the impeller. The fluid is jet A. At first glance it looks like gauling as a result of mechanical failure. A closer look reveals a surface texture with wavelets around the perimeter of the impeller and the housing and very highly polished surfaces. Looks nearly as bright as electro polished aluminium. Many thousands of these pumps are in service but only two have experienced this problem./w3tcompact/icons/frown.gif
Al
/ Antifreeze/Engine Coolant #32
Here is a tid bit I got from my dealer last week. A couple of weeks back the dealer was having a presentation on JD parts and supplies. I wanted to go but could not. I called my sales guy last week on another issue and we started talking about the presentation. He said that the biggest problem that JD sees is caused by not changing the coolant on schedule and with the correct product. The dealer certainly knew about the problem caused by using the wrong type of coolent. He said they had a cylinder with the pitting as well as a hole(s) going through the metal.
FYI,
Dan McCarty
/ Antifreeze/Engine Coolant #33
Check out the peak antifreeze site, www.peakantifreeze.com . The technical discussion talks about fleet charge. According to that you still need to perform sca maintence. What is that, add sca or replace antifreeze?
Does sound like you could use it in everything. Do the sca's make it a wetter antifreeze?
/ Antifreeze/Engine Coolant #34
That's the first I've heard that you need to keep checking it. I use Fleet Guard and it doesn't say anything about having to check it all the time. It's not a wetter antifreeze but it's just additives to the antifreeze to prevent the cavitation effect.
/ Antifreeze/Engine Coolant #35
I talked to the tech guy at Fleetguard this week and he said that you do have to chech it a few times a year. I run ES Compleat in my '95 PowerStroke. A convenient way to get samples to perform the check, and to enable flushing when you do change it out, is to add a John Deere coolant eye. It goes in-line in a heater hose , like a Prestone flushing tee, but sooo much more. = : ]
Eric
/ Antifreeze/Engine Coolant #36
Yea they also have an inline filter that will release the additive into your antifreeze as well. That is the setup that Navistar has on the Ford engine in all other apps. For some reason Ford deleted that setup when they put the powerstroke into their pickups. Ford now has an ELC that they put in them.
/ Antifreeze/Engine Coolant #37
What's an ELC?
RCH
/ Antifreeze/Engine Coolant #38
ELC=Extended life collant
**Last I read Ford said No on the ELC on the powerstrokes. I have 1997 and Ford only likes the green stuff. I have no idea about 2002 models though.
I would check the SCA levels every 6 months. Cheep and easy.
Mike
<P ID="edit"><FONT SIZE=-1>Edited by burnickas on 11/17/01 09:51 PM (server time).</FONT></P>
/ Antifreeze/Engine Coolant #39
Mike,
Ford came out with an ELC this year for the powerstrokes. It's orange.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
2022 TEXAS PRIDE GOOSNECK (A65643)
2022 TEXAS PRIDE...
Curtis 80 Gallon Air Compressor (A65640)
Curtis 80 Gallon...
