another years wood supply
/ another years wood supply #1
WayneB
Elite Member
New Hampshire
Kubota B-7500
Finally got my wood cut and split, now all I have to do is bring it in and pile it! Never ending task.
The snow pile behind is actually covering more split wood.
Once the snow is down I can start moving and piling the wood.
/ another years wood supply #2
Looks like a lot of work. How long did take to make that pile.Do you heat
totally with wood must help a lot on heating bills. Plus you probably don't see
the doctor much with that work out.I don't cut any more winters in ks. not
to bad anymore.Beautiful country New Hampshire.We have ex pastor and wife
in mission field there. They tell us about winter there.Can be little cold and snowy.Good luck . Framer
/ another years wood supply #3
There's a lot of satisfaction in seeing the result of your labours piled up like that. I don't have a wood lot but I'm waiting on an 8 chord truckload of logs. I hope the ground is frozen when it gets here.
/ another years wood supply #4
So........... when was it you said you weren't going to be home ???
/ another years wood supply #5
Good Mornin Wayne and Scott,
Yep, and leave the chainsaw and splitter there also ! :D
/ another years wood supply #6
Are those long splits or are they just split down really thin? Lot's of btus in that heap.
/ another years wood supply #7
We heat our house with wood (propane as a back up). I've never bought logs to split. What's an idea of cost on something like that?
/ another years wood supply #8
Central Nova Scotia it's about $100Cdn per cord, 16 feet long, minimum load of 6 cords delivered. Cut, split and delivered is anywhere from $150 to 250. I use oil fired hot air in my place.
Steve
/ another years wood supply #9
A semi-load (~10 face cord) of 8"x8' hardwood logs cost about $1K last fall maybe less now.
framer: Working on and off on it. Normally I would go out and cut for an hour or two and then split what I had cut. We got hit with a few snowstorms in December so that slowed things down, plus the other things we are doing around here. We heat mainly with wood and have an oil furnace for backup when we are going to be away. We have had around 70" of snow this year so that isn't too bad and there have been a few days that were -10 or colder but that is it for this year so it hasn't been too bad.
Tig: I cut a bit off the land and also had a grapple load delivered. got it the week after Thanksgiven and then we got the snow in December that slowed down the cutting and splitting a bit. I think there is about 8 to 9 cords there, but won't really know until I get it stacked.
Ductape: Heck we are away most of the time, just drive right up, oh did I tell you I got a new 1911 and case of 45 rounds!
scott_vt: Heck the chainsaw is old and the splitter needs an oil change, you wouldn't want them.
Highbeam: Started out as long logs some pretty good size. I split everything down so as to dry better and it is easier to haul into the house for the wood stove. If I am lucky the wife will bring it in if split small enough!!
bhostasa: Well the cost around here for a grapple load is anywhere from 650 to 900 dollars. I paid 700 for the load I got. Two years ago I paid 550 to the same person.
Steve_Miller: BarryinMN: Barry a semi load around here, talking about around 30,000 lbs will cost around $1,600. Problem is having space for the dual trailer rig to get in and out. Steve that is about the same USd here for log length. Split and delivered will be anywhere from $200 to S350 a cord in my area. Tell you at $350 a cord I would have to think hard and long and then turn up the oil furnace.
/ another years wood supply #13
Ouch. My back hurts just lookin' at that pile.
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Altec DC1317 Chipper (A63689)
Altec DC1317...
