another vickers pump question
/ another vickers pump question #1
dodge85rc
MN
trying to find some specs on a hydraulic pump I got. The letters in the casting are hard to read so not sure if these are right.
It is a Vickers pump, looks like a 105-c-12 ? It is a square housing if that matters.
Thanks!
/ another vickers pump question #3
Best I can do, is guess. A V-105 pump would be round, so, I know that can't be it. The only thing I can find that might be close would be V210-5-1C-12-S214. That would be a vane pump. Rated @ 5.4gpm @ 100psi & 1200rpm, and 4.3gpm @ 2000psi & 1200rpm. And a max rpm of 1800. I'm not sure where the model number would be stamped.
I'll try to take a wire wheel to it and try to clean it up and see what numbers are really there. Thank you
Where do you get your specs from?
I have another pump/motor I need to find specs on too.
It is a hydreco 1510c3c1
Anybody know any good websites to find specs on hydraulic equipment?
/ another vickers pump question #7
hydreco is an old name.
I remember mentioning that name back in the '60's
i don't know /can't remember much more
maybe you can find something here for the vickers pump
http://devcocorp.com/american/vickers_vane_v.pdf
maybe post a pix?
google vickers or eaton I bought some seal kits for my V 210 pumps a few years ago and remember finding a link to those pumps.
the identification is
on the rear housing it should be stamped and the model and cartrage installed
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A67714)
2016 PETERBILT 567...
STERTIL SKY LIFT (A67714)
STERTIL SKY LIFT...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
Iranch High-End Tricycle (A64119)
Iranch High-End...
