another smoke question
/ another smoke question #11
New Ring
/ another smoke question #13
Yep, that's a classic pic of a worn ring, you can tell by the end gap. Next question is do they wear the bores as well or just the rings? Some engines are prone to doing one or the other, you hope it's just the rings and that you can just hone the cylinders out.......
Don't forget to check that gap both at the top and bottom of the stroke on your new rings, you may have to file the end a bit if it's too tight.
/ another smoke question #14
/ another smoke question #15
The bore wasn't worn at all. Just honed it replaced, and 100 hours later it has used no oil or shown any oil smoke.
/ another smoke question #16
sorry it's taken a while to respond. Vacation rocked. First thanks again for all the help and advice guys. Generally it smokes a little white all the time. Maybe bad fuel, H20 in the tank due to infrequent use, ambient temp./humidity, who knows. After asking a few questions on here a while back I decided I wouldn't fix what wasn't broken. Heck it's a diesel. They all smoke at times right. Well, a few weeks back I put the hog on and decided it was time to cut about 7 acres of pasture. I noticed when cutting the white smoke became almost non existant. Clear exhaust. Wow! That was cool. A fuel tank later and a refill of fresh after I was done cutting I took the hog off. I noticed the white smike again. The next day I did some pretty decent grading spreading crush over the back drive to one of the barns I noticed the smoke the whole time grading. I did notice a small drip of fuel from the bottom of the filter bowel. Befor I could address the issue it completely stopped. no more fuel drip. No drip running or stopped, hot or cold. There was never any change in the oil levels, no change in the engine sound or preformance. No temp changes, just the same old that was easy attitude from the tractor wether smoking a little or not.
/ another smoke question #19
Try changing your filter bowl "O" ring. If fuel can leak out, air can get in, and cause your white smoke.
/ another smoke question #20
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2017 Nissan Rogue AWD SUV (A59231)
2017 Nissan Rogue...
