Another question on Quick Connect Compatibility
/ Another question on Quick Connect Compatibility #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
I have a Kubota MX5100 with Faster HNV quick connects on the Power Beyond port for the backhoe. These HNV are supposed to be ISO 7241-B series. The male connector has a nipple, not a ball valve. Should I be concerned about compatibility if I get some other brand of connector, such as Parker 60? The point of an ISO spec is to ensure compatibility, but I remember seeing some posts where it appeared there might be tolerance issues.
I found some Series-B on discounthydraulichose.com that appear to look like the Faser HNV connectors, the only downside to trying them is the shipping cost is $17 for a $20 set of valves.
Thanks in advance for any help...
/ Another question on Quick Connect Compatibility #2
Parker 60 Series couplings comply with ISO 7241 Series B Standard according to the Parker Spec Sheet. http://www.mrostop.com/pdfs/gen_purpose_qc.pdf
I am 99.9% positive even though I have not referenced the spec sheet that HNV's are 7241 B compliant.
I have a mixture of Faster HNV and Parker 60 QD and have no problem at all.
FASTER Crossover Guide - Hofmann Fluid Power, Inc.
is a good crossover guide tool.
Shipping costs can eat your lunch. If you are only going for a single QD might be better to buy local.
I personally prefer the "poppet" style QD over the "ball" design. Many say they leak less and I think I find they are less troublesome in general.
Make certain that you know the thread type you are looking for as some tractor manufacturers stay straight ORB and some use a lot of NPT. You do not want to buy the QD for what you don't have and then have to go buy a conversion fitting as well. The exception to this might be if your hoses are NPT, I might get a NPT to ORB fitting and never remove the NPT once it is on. They can be temperamental if you remove them and do not carefully clean the threads before re-installation, resulting in hydraulic leaks.
I AVOID NPT if there is anyway possible!!!!!
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
Claas Lexion 400 Series Combine Parts and Service Manuals (A63117)
Claas Lexion 400...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2016 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
213080 (A64276)
213080 (A64276)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
