Another PTO Generator question
/ Another PTO Generator question #21
If we are talking about the JD letter series.. Like a 'B' for instance.. where the motor is tach'ed out at 900 rpm... I still feel that if you are running rated load for the hp available, and the governor on the tractor is holding the rpm steady.. you will have no problems. My B is decently strong.. I have no doubt that it is stronger than my 4 cyl 8n that runs at 2.5x the rpm..
While the lower engine rpm would be a problem in so much that a drop of 10rpm from the engine would be seen as almost 5rpm drop from the pto... If the tractor governor is keeping the rpm solid.. then it's not a problem. No more problem than a 1 cyl gas engine on a portable genny.. like a 3250 - 550 - 6500 watt job you get at a box store....
Soundguy
/ Another PTO Generator question #22
I'm not speculating on if it will work evenly or not . I have run a generator on a JD60 & know the output is not smooth .
/ Another PTO Generator question #23
I'm not speculating either. My B has a rock solid enigine that will hold rpm.. perhaps your 60 wasn't up to the task? Or the genny was too much of a load? As of yet I have not put a full 12.5kw load on my genny.. probably only half that.. and at that level of load, my oscope, freq counter and peak/rms reading VOM say freq is as good as house current, and voltage stabilization ( passive /capacitive no less ) is as good as house power.
When I bought my genny ( a northstar unit ) I was concerned about the cleanliness of the output, and specifically set up some load tests. I use all my 20+ hp gas tractor as well as my big diesel... no noticible difference.
I think the key isue is electrical load. A low load like I was using or like a small 1 cyl lawnmower engin'ed portable generator may not be enough to heavilly load the genny.
Figuring very graciusly.. if you alloted 2 hp per kw produced.. 6kw only uses 12 hp.. and my b put out plenty more pto hp than that. Might not work as good at higher load rates.
At issue is number of generator poles. A unit with more poles will be less sensitive to rpm drop at the pto due to load increase and governor response. I.E. a 1800rpm unit vs a 3600rpm unit. A drop of 1 rpm at the pto is felt twice as much on the 3600 rpm unit...
I'd go with that conditional explanation.. but not a blanket " no 2 cyl engines' on a pto gen set... etc..
Soundguy
/ Another PTO Generator question #24
If you are going to buy a generator for a rainy day, that's nice. Be aware that you need to run the generator every 6 months or so so it won't loose it's magnetism. If it forgets that it's a generator, you'll need either a 110v source of power or another generator to reenergize your dead one. This could be interesting come a power outage. A generator is not something you buy and just throw on the shelf waiting to use.
/ Another PTO Generator question #25
</font><font color="blue" class="small">( If you are going to buy a generator for a rainy day, that's nice. Be aware that you need to run the generator every 6 months or so so it won't loose it's magnetism. If it forgets that it's a generator, you'll need either a 110v source of power or another generator to reenergize your dead one. This could be interesting come a power outage. A generator is not something you buy and just throw on the shelf waiting to use. )</font>
And of course you are going to want to let the generator run with a load.
I bought a 15KW Guardian Ultra Source Portable Generator
long before I bought a tractor. But, it sure would have been nice to have a PTO or diesel instead.
Generators can be worth their weight in Gold. /forums/images/graemlins/smile.gif
http://tinyurl.com/al8s4
/ Another PTO Generator question #26
Mine is one of the Protran series from Reliance as Norm's link shows. I bought it at CED electrical.
/ Another PTO Generator question #27
</font><font color="blue" class="small">( thanks, You wouldn't happen to know the average wattage draw of a well pump would ya? I have no clue what it would draw. Kinda hard to see the tag on it since it is 350 ft down a small hole. /forums/images/graemlins/grin.gif )</font>
How Much Electricity Do You Need to Produce?
Wattage Calculator
http://tinyurl.com/8gcbo
/ Another PTO Generator question #28
Just a quick update. I emailed my JD tractor buddies about their thoughts on 2cyl's and pto gens. These are the verbatum results I got.
40, 50, 70D, 80, 435, 720, 730D All fine work horses for flicker free genney operation. Note: A few people were running about 10hp more pto power than needed for the generator at full load.
60 / 70 G, Note: they sometimes hunt causing flicker, when the tractor was at partial load. At full load, they seemed fine and solid.
Soundguy
/ Another PTO Generator question #29
Another reason people want PTO generators, instead of a standalone portable one, could be simple...
I have a Steiner lawnmower with a Kubota diesel engine. It gets used pretty much at least twice a month, come rain or shine. I also drive a tractor trailer for a living, and bring it home every night with me. In the event of a major storm, hurricane, or just the power company blowing off steam, I can hook the lawnmower to my PTO generator, and run it for pennies. It will run about a day one the fuel in the tank before I have to start worrying about where to find diesel. Then I use the fuel in the John Deere, another 20 gallons. In the event of a major problem, I am sure my company would allow me to borrow enough fuel to keep it running. That means I have a 250 gallon storage tank in the driveway of FRESH fuel, should the need arise.
How can you be better prepared than that? My PTO generator is a small one, 10KW surge, 7.2 KW continous, but that is what would run on my lawnmower...
David from jax
2013 WACKER NEUSON HF 690 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2013 WACKER NEUSON...
2009 FORD E250 CARGO VAN (A66091)
2009 FORD E250...
CRATE OF MISC ELECTRICAL WIRING (A68842)
CRATE OF MISC...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
HERRING 500 BBL FRAC TANK (A68842)
HERRING 500 BBL...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
