Another newbie needs advice....
/ Another newbie needs advice.... #1
boze_man
Bronze Member
montana
Kubota L3130 HST w/LA723 FEL
Not sure if I should post here or in the Massey forum??
I am considering purchasing a tractor and need some advice. I live in Montana and have 16 acres of pasture (some flat, some contoured), no livestock yet, a quarter mile gravel driveway that needs help. Also the property around the house is in need of some finish landscaping, grading, and cleanup. I would use the tractor for road maint, snow removal, pasture cutting, landscape grading, fencing, moving small trees/shrubs, maybe spraying etc.
I have all the major dealerships nearby, JD, NH, Case, Kubota, and Agco/MF, so I could purchase a new unit, but being new to tractors I would prefer a used one. I love the idea of a tractor, but not sure if I have time to take on these projects. Also I am not sure if we are going to be here long term. I feel that if I get a good used one at a good price and I need to sell at some point I won’t lose as much as selling a new one. Hopefully this makes sense.
There is a lack of used 4wd compact tractors locally, but the MF/Agco dealer has 2 used tractors, both ex-rental/lease. First one is a 2001 MF 1165 w/FEL, 37 pto hp, powershuttle, w/ approx 500hrs. dealer asking $16,900. The other is a 2000 Agco ST45 w/FEL, hydro, 36 pto hp, w/ approx 350 hrs. dealer asking $19,900. Also I think he said there is an extended power train warranty on each, not sure though.
Initial attachments I am looking to purchase are: rear blade, rotary cutter, and landscape rake. I think that should cover most projects to start.
I could get a new NH TC 30 or Kubota B7800 at the same price of the used MF 1165, but I feel it is better to get more hp than less.
I need some advice on:
1) the pricing of the 2 used tractors?
2) the reliability of the 2 used tractors?
3) the resale potential of the 2 used tractors, also vs. a new one?
4) what size? are the 2 used tractors too big fro my needs?
5) should I just forget used and go for new?
6) any opinion in buying an ex-rental/lease?
7) which attachments should I start with?
Also I have not been able to find any info on the MF 1165. Any help?
Hopefully i haven't confused everyone here. I am just trying to determine best course of action.
/ Another newbie needs advice.... #2
AT least you have some used options.
I really only had one dealer that i would consider for personal reasons mainly. He didn't have anything used I was interested in. The only used stuff he had was so nearly new that there was not much price difference.
By the time I took advantage of the 0% interest rate on new it was actually cheaper than used.
Point here is - look at the financing options closely - you might actually get into a new one and have full warranty for what you might pay for a used one with higher interest.
I guess if you are paying cash that wouldn't matter much. Unless you put the cash into an investment and take the 0% financing...
It's always nice to have the new warranty and not worry about buying someone elses problem as well.
You will know how it has been maintained and that you have a good reliable tractor.
The tractor that I bought with my house was supposed to be in decent shape.... I was spending more time working on it than with it..... So I just went and got new and now I with it and not on it.
These little tractors seem to hold their value well - so even with new you probably wouldn't loose bad if you turned around and sold it in one year.
Be sure and buy more than you think you will need - it makes it all the better.....
/ Another newbie needs advice.... #3
I forgot to mention
If you are going to be doing much of any landscaping I would get a front end loader as well.
I dont recall seeing you mention that you wanted one of these in your post.
I think it is probably the most valuable thing I have....
Just a thought !
happy hunting
tomtom
tomtom
thanks for the reply.
good point about the financing and warranty. i will look at closely and consider all options.
regarding the FEL, i will definitely get one. i did not include as an attachment because they seem to always include them as 'standard' now.
/ Another newbie needs advice.... #5
I suffered the new vs. used dilemma. Have to agree -- look at the difference in financing (0% saves a lot of money over the years). You'll probably save more than enough to offset the extra cash for new. New gives you a warranty, a better selection, and the opportunity to tailor the equipment to your needs. Used can turn into buying someone else's problems. "Working" the tractor is always better than "working on it". Always, always buy just a bit bigger -- you'll be surprised the number of things you'll find that need done and there is nothing worse than wishing you had that extra horsepower, etc. Definitely need the FEL! Most of the other attachments - box blade, rake, PHA - are relatively cheap, but worth the money. I have the luck of sharing attachments with neighbors, so only one of us had to buy the expensive backhoe.
/ Another newbie needs advice.... #6
You're on the right track.. I bought my last 2 NH tractors a coupl eyears old as lease returns from my NH dealer.. good money savings.
I think those two you mention are ok on price.. but maybee still a tad high. When it comes down to new vs used.. if the used is only a bit cheaper than new.. it sometimes 'pays' to go new. Also.. I've seen a new tractor be only a thou more.. and have better ( 0% ) financing, whereas an 'identical' used one got the 'used' rate of 6% and in the end.. costed more.
Like I said.. you are on the right track.. keep looking and then you can make a good decision. It may be that the used market in your area closely parallels the new market, and that may be the only 'margin' savings you get.
Try to find an eicher dealer.. they sell a decent new tractor at a used tractor price.. but are not as 'questionable' as some of the super cheap economy brands.
Soundguy
rider, soundguy thanks for the reply.
the 2 used tractors are maybe?? a bit more than i need, 45 gross-37 pto hp, bigger frame, etc, and would easily cost over 20k new. i guess the question is it better to get a larger used or smaller new?? and which would have better resale. for example i could get a new NH tc30 w/30 gross hp or the used MF 1165 w/45 gross hp for approx the same price...
i am having a problem comparing apples to oranges...
/ Another newbie needs advice.... #8
Just my opinion.. but buy a little bigger than you need.
Resale on CUT's stays decent. Resale on newish larger tractors is ok as well... resale on older ag tractors falls off a bit due to low demand.
Some of it is a time issue... I get 4 days a month off... I traded in my beloved NH 1920 (33hp) and got a huge NH 7610s ( 90hp ) so I could pull a 5' mower.. and cut my mowing time down from 6hrs to 3 hrs...
The time issue meant enough to me to do that. And those were the two NH I was talking about.. both were 2ys old when I bought them from the dealer. The dealer gave me almost the same purchase price for my traded 1920 as when i had bought it a couple years earlier. ( I took great care of that machine.. )
Soundguy
/ Another newbie needs advice.... #9
Boze man,
the fact that you are having a hard time finding used would indicate to me that the resale will probably be higher when you sell if nothing changes.
I bought a rental return and thought it was a good deal. I also agree with SoundGuy......get the larger tractor as long as its not too big to use. (ie. fit in a barn, go around trees, etc).
If you store it inside and take care of it, not only will you get a lot of years of good usage but you should get a good resale price as well.
Best of luck,
Mark
/ Another newbie needs advice.... #10
</font><font color="blue" class="small">( There is a lack of used 4wd compact tractors locally )</font>
Another way to look at it is, if u buy new and don't stay there that long , seems like you wont have any problem selling the tractor.
NEW VS USED? depends on the tractor and the deal u can make. this is really an individual decesion, based on the tractor, the price and YOUR overall thoughts on it.
/ Another newbie needs advice.... #11
The only advice I have is to be careful w/ buying equipment that was formerly rented or leased for a couple of reasons. The first reason is that some people who rent equipment operate the heck of out of them w/ no regard for wear & tear on it. It amazes me how much some people live up to the quote "drive it like you rented it". The second reason is maintenance on the equipment. Make sure the rental agent is reputable and has a competent service department that performs the required maintenance of their equipment. A leased piece of equipment probably would be a better buy because the lessee knows they will be keeping it for a while and probably performs regular maintence and uses care to keep the equipment performing the best it can. Just my opinion...take it w/ a grain of salt.
thanks all for the advice.
i have been speaking to the dealer about the 2 rental tractors. he put together a package price of $17700 for the MF 1165 w/MF 232 FEL, powershuttle, 6' cutter, 7' landscape rake, and 7' rear blade. sounds pretty good. any thoughts??
they r a MF/Agco dealer and he said they service these rentals regularly. also the MF 1165 has been with 2 renters. so hopefully it is in decent shape and hasnt been abused too much.
the Agco st45 has been with many renters, since it is a hydro. his price on that with the same attachments was $21000.
anybody know anything about the 1165?? i have not been able to find out if it is Iseki or not, and if it is a decnt tractor. one web site said it was isuzu?? i have posted on the massey sight but no feedback yet.
will let you know which way i go...
thanks
/ Another newbie needs advice.... #13
</font><font color="blue" class="small">( Make sure the rental agent is reputable )</font>
I agree.. i would be much more wary to buy rented equipment from a rental agency.
My two rent/leased units came from the dealer.. one owner jos.. still under warranty, and factory serviced.
Soundguy
/ Another newbie needs advice.... #14
</font><font color="blue" class="small">( so I could pull a 5' mower.. and cut my mowing time down from 6hrs to 3 hrs... )</font>
I'm sure you meant to say, "So I could pull a 10' mower." Since I know you bought one!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif John
/ Another newbie needs advice.... #15
Yep.. big typo..( big fingers.. ) but when i found it it was already past the time to edit it.
Soundguy
hello all
thanks for your opinions, very helpful...
i have been thinking that maybe best to go new, esp with financing and warranty.
considering the TC33DA/DX33, JD4310, Kubota L3130. (all current local inventory).
any opinions?? they all seem like great machines. hard to compare apples to apples. specs all slightly different.
also could go for class 3 - TC35DA or DX40. (current inventory), big price jump compared to others....
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 INTERNATIONAL MA035 VACUUM TRUCK (A59905)
2013 INTERNATIONAL...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2019 Ford Transit 250 Cargo Van (A59230)
2019 Ford Transit...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
