Another MX5200 Runaway Diesel
/ Another MX5200 Runaway Diesel #1
tyinusn
Hamilton, VA
MX5200
There are at least two posts on the forum about runaway diesels in the MX5200. Those were attributed to freezing weather. Well, this one is a 90 degree day in August. The video shows the last few seconds of the tractors life. This is after about 45 seconds of trying to shut it down and getting away from it.
Dealer and Kubota act like they have never heard of this. Going on a month without my tractor as they figure out how to replace it. Only 60 hours on the engine so Kubota is not high on my list of quality companies.
/ Another MX5200 Runaway Diesel #2
It's new engine tech ... Still bugs to work out. Just think, you'll get new engine, maybe a whole new tractor!
/ Another MX5200 Runaway Diesel #3
Keep us informed about how this plays out.
/ Another MX5200 Runaway Diesel #4
Ouch. The MX5200 is a nice tractor. I liked it a lot when I was shopping early last year, but it wasn't offered with a cab. I have no doubt Kubota will do the right thing for you on this.
/ Another MX5200 Runaway Diesel #5
Ow! That hurts! I'm sorry for your loss. I know you were expectinf many, many years of good service. Hopefully Kubota will make it right. Is this problem likely to happen to all of these models? Man, that could be deadly if you were working in a "tight situation."
Good fortune!
Scott
/ Another MX5200 Runaway Diesel #6
For future reference, when a diesel engine starts to run away, immediately cover/plug the air intake. It will cut right off no mater what else is the problem. Anything will do -- a rag, a hat, your t-shirt, etc. From the looks of it, the OP never even opened the hood.
/ Another MX5200 Runaway Diesel #7
I agree with s219, but keep in mind that if the air intake doesn't have a screen on it, keep a good grip on that rag or t-shirt. I have seen rags get sucked into a runaway diesal and go all the way out the exhaust. The motor had a blower which chewed it up and made it easier to swallow, but you don't want a rag stuck somewhere it shouldn't be. If you are working on one and running it without the normal air intake system in place, keep a board handy. A clipboard works great to cover the opening.
/ Another MX5200 Runaway Diesel #8
I had a diesel tractor run away & quickly turned of the fuel supply before it blew up. Turned out it was a stuck fuel rod in the injection pump.
/ Another MX5200 Runaway Diesel #9
My father was a diesel injection pump mechanic. He told me to break the fuel filter glass. But if the engine runs by ingesting lube oil then covering the air intake is only way to stop it.
So, you would approach the size of the engine, pull pin on grille guard, pull grille guard forward, put face near hood, pull hood release, open hood, lift hood, open air intake, stuff rags in.... All while a tractor designed for 3000 rpm max is racing at over 4000 rpm. You are braver than I my friend.
A thrown rod or fragging turbo will kill you. Brave is occasionally the camouflage of DUMB. The design of the Kubota does not allow a safe way to kill a runaway. If there is a large CO2 canister handy then that is the best method. Unfortunately I left mine I the runway of the airport. Probably need to tow it at all times.
Kubota has had the tractor one month. No concession or upgrade, despite numerous 5200's doing this. I MAY pay the difference and get the 5800. But their only offer has been a replacement of tractor only. Loader and valves get moved.
/ Another MX5200 Runaway Diesel #11
Have they told you the cause?
/ Another MX5200 Runaway Diesel #12
Years ago I was taking a fuel injection class. One of the students started a 6-71 Detroit and an injector stuck in full fuel! Fortunately the student had enough presence of mind to slap the emergency stop before taking cover. After we all emerged from cover we were all abuzz about the runaway diesel. The instructor comes up and dead pans, "I did not see a diesel running away, I saw a bunch of students running away!":laughing:
/ Another MX5200 Runaway Diesel #13
Replacement tractor has been offered and you aren't happy with that???
Loader and valves are added at dealer level anyway, they don't come from the factory that way.
/ Another MX5200 Runaway Diesel #14
If you're in the seat when it runs away, you could stall it by putting it in a high gear and standing on the brakes. Maybe dig the loader into the ground too.
/ Another MX5200 Runaway Diesel #15
Agreed. If they are offering a new tractor, take that offer. Right now!
/ Another MX5200 Runaway Diesel #16
Conspiracy theory here: Will the new Kubota Bomb be rigged to blow up when you turn the key on?
If they have not fixed the problem, and the new tractor in 60 hours or so does the same thing, will they say that its your fault? Or will they give you another new tractor?
Be careful, dont jump on their offer too quickly. Ask plenty of questions and leave nothing to chance. It has already taken them over a month to offer to replace it. They probably will not replace another out of the kindness of their heart.
Good fortune!
Scott
/ Another MX5200 Runaway Diesel #17
I hope the op provides more information. I'm quite interested in the particulars of this case.
/ Another MX5200 Runaway Diesel #18
I had a diesel genset get away from me once, was running on engine oil that had been overfilled. Pretty exciting stuff ! Got her shut down by blocking the intake.
/ Another MX5200 Runaway Diesel #19
Just what every customer dreams of, getting a new tractor so they can work the bugs out of it, for the mfg!!
I'd call EVERYONE at Kubota until I got someone, who would approve MY "demand" to pay a reasonable difference, for a DIFFERENT model, as this isn't the first time (or even second) it's happen to this model!
SR
/ Another MX5200 Runaway Diesel #20
:mad:BEING A DIESEL MECHANIC FOR 40 PLUS YEARS THE WAYS ADRESS TO STOP A RUN AWAY ARE CORRECT BUT IF YOUR IN THE SEAT WHEN THIS HAPPENS ITS A LOT DIFFERENT IM GLAD NO ONE WAS HURT BEST OF LUCK WITH GETTING A SATISFACTORY RESULT IF KUBOTA READS THESE FORUMS THEY SHOULD SEE HOW PEOPLE FEEL ABOUT THIS AND TAKE NOTE TO TREAT YOU RIGHT.
