</font><font color="blue" class="small">( I've got a question.)</font>
several, as it turns out.
IMPORTANT: BIGBEAR's question that started this thread concerned his 354 JEPE. You've managed to turn it into a Jinma thing, and not all Chinese tractors are Jinma clones. So it's important to note that my responses to you are Jinma-specific and are unrelated to BigBear's original 354 JEPE question, or to Chinese tractors in general.
</font><font color="blue" class="small">( If (since) UTF is designed as a gear lubricant ( final drives.. etc... ) why won't it work in the rear end of a jinma? )</font>
I don't recall anybody saying it wouldn't. What HAS been said repeatedly is that "gear oil is for gears", and that "UTF has a gear oil component". But I still recommend non-foaming 80W90 for Jinma transmissions and differentials.
</font><font color="blue" class="small">( Same question for the tranny.. especially since I see some many questions about the issue of the creeper gear not getting lube with thick gear oil..e tc.)</font>
The dry creeper issue is one of contamination, not of lubricant choice. It's relative to the dirty 30W that's apparently put in by Jinma for storage and transit before sale, and is one of the prime reasons the kerosene flush is recommended before putting these small Jinmas to work.
</font><font color="blue" class="small">( Same for the power steering? just about every other 'modern' tractor I've seen with power steering either recomend their labeld brand of utf for the PS.. or it shares a commpn sump with some other item, again.. using utf.. etc.)</font>
See, there you go again Chris. If you actually owned one of these things, you wouldn't come up with all this second guessing. The smaller Jinmas employ only one pump - in a closed loop configuration. Whatever fluid you pour into the hydraulic reservior is used for everything hydraulic on these units.
</font><font color="blue" class="small">( Chinese pumps not up to pumping anything thicker than water? Or is there other restrictions that the oil weght is super critical about?)</font>
Again, it's not the pump - it's the cheap hydraulic suction filter - something you'd already have learned, if you owned one in cold country.
//greg//
