Another lackender order placed
/ Another lackender order placed #41
bubenberg:
<font color=red> tree sheer, platform to trim branches and high bushes</font color=red> Yes, a tree shear! And a work platform! With Power Dumper too maybe? I want one.
<font color=red> if you can swivel that thing </font color=red> Sure can, note the gimbal & "reins" on my sketch.
<font color=red> your lunch wrappers, starboecks coffee cubs, coca cola cans from your crew</font color=red> And here I thought recycling bins were just for under the kitchen sink. A truly sensitive grabber, will it pick up an egg?
With all this automation we'll all need to a personal trainer for some exercise.
On our Starboeck trip to Spencer N Y to see one attachment for the Lackender backhoe we will if you would like and pick you up to see this thing.
log grapple for skid steer
The Valby skid-steer grapple has an opening of 50 inches, and a rotator with over 700 lbs. of torque. Optional grapples and rotators with openings from 50 to 100 inches can be viewed by clicking here. It requires two sets of hydraulic outlets from the skid-steer. One set runs the continuous rotator, the other set opens and closes the cylinder. This attachment enables the skid steer to be used for moving and stacking chores on the landing, or in the yard. The skidding grapple has a universal mounting plate.
Wait what i found for the ditch mower for compact tractors and skid steers.
To satisfy one aspect of your desire for exercise here is a perfect way to do both work and exercise:
THE ASCENDER
Technical Specifications
Three mast lengths available (17, 21 and 25 feet) which allow pruning to 22, 26 and 30 feet, respectively, with our short saw. Each ascender comes complete with mast, pedal power unit, safety harness and line, and all other hardware with extras. Total weights, 51, 56 and 61 lbs. respectively. (saw not included)
http://www.futureforestryprod.com/products/ascender.htm
me i will try to automate the thing via hydraulics
Sedgewood for your perusal <font color=red> platform to trim branches and high bushes </font color=red>
Work platform available in two sizes comply with OSHA regulations. Each unit comes with four 4in. x 2in. mold-on rubber casters for portability. 60in. high expanded metal back, dual locking gate and four-way safety treadplate. Both also have 4in. high kick plate, safety instruction sign, 42in. high hand rail with 21in. mid-rail and 36in. safety chain to attach to fork truck. Tine locks lock platform to forks. 2.5in. H x 7.5in. W fork pockets. Truck ship. U.S.A.
Sedgewood you think i was kidding! As promessed here is the ditchmower:
http://www.vmc-mow.com/
see you on sunday but i am only bringing a tree to be cut into boards and a Kubota ZTR for Charlie to try, no new gadgets this time.
hrl
Charlie, while talking (per phone) to the finish rep for valby he indicated that most skidsteer owners only buy the rotator and the grapple combination Valby GR-36 at $1190 and mount it to the backhoe rather then paying for the total skidsteer attachment of $2500.
for further info:
http://www.valbysales.com/index.htm
/ Another lackender order placed #47
Hans:
Check with PT on the new dump trailer, have not seen it on their web site. Are they making different sizes?
PJ
you should know things will be done in do time "down here". you won't believe how many times i asked them to finally post a picture ... i will try again on Monday next. but i have tried longer to get the exact nomenclature for the hydraulic filters ... oh well
wish me luck
We made the front page of TBN again
Thanks for the well wishes, please put your thinking cap on and make a X-mas, hanuckka list for all your needs, concerns and wishes and get it to Charlie, John or me NLT early Sunday morning (3 November 2002)
/ Another lackender order placed #51
Re: We made the front page of TBN again
Ok, my wish list is as follows:
- hydraulic powered chipper/shredder
- hydraulic powered hedge trimmer
- work platform
- more lights forward and aft
- hydraulic powered generator
PJ
got it, thank you
/ Another lackender order placed #53
PJ, hydraulic powered generator
PJ:
That wouldn't be too hard to build. Harbor Freight has a 10KW generator head (http://www.northerntool.com has a variety of hydraulic motors to choose from. You'd just need to build an attachable frame for it. Since you only need to carry it around (not dig with it!), you could probably use a bolted together frame rather than needing to weld it. Just a thought...
Dave
/ Another lackender order placed #54
Re: PJ, hydraulic powered generator
Dave:
Thanks for the threads, will check into it. If I can use the hydraulics off the tractor this should save money and still get a large watt unit. We get a fair amount of lines down in the winter, summer is no problem.
PJ
/ Another lackender order placed #55
Paul,
I don't know how much money you would save. A hydraulic motor, couplers, lines, quick disconnects all add up. Figure about $300 or more for the motor and hoses and stuff and you could by a gas motor for that much. Now, if you want to do it so that you don't have another gas engine to maintain, that's a different story. I could agree with that( remember I'm still looking at chippers and blowers to run off of the PT because I don't want so many gas engines to maintain ).
Having some expereince with my generator, I've found that when the power goes out, there is usually storm damage that I want to clean up. If the PT is tied up running the generator, you can't do the cleanup. Also, this tends to happen at night to me. I use the generator to run some lights to do clean up or for security. Also, my wife's family lives near. If one of them needs to borrow the generator, I take it over and hook it up. But there is no way I'm loning out my Power Trac /w3tcompact/icons/laugh.gif
So, to me at least, the generator is about the only thing that I wouldn't want to run with the PT. Everything else in the garage should be converted to hydraulic!!! /w3tcompact/icons/tongue.gif Hope this helps.
/ Another lackender order placed #56
MossRoad:
Thanks for comments; you brought up a few points I had not considered.
Your correct about the need for tractor use during the time power is needed. Every time I turn around I seem to be fixing some gas motor. Need to reduce the number but this will not be one of them.
I'm most interested in using a lift that I can trim hedges using hydraulics for power.
PJ
Dear Pter,
if ever possible please post your wishes by tonight, Saturday 02 November 2002. We (Charlie and I) would like to consolidate all your wishes, questions and suggestions; then type them out so that we will be as organized as possible when we get to Tazwell tomorrow night.
Thank you in advance
hrl
NEWS FLASH ... PT HQ .. VISIT ... NEWS FLASH ONLY
For right now just an update, details later.
pt build one power dumper and sold it on the spot.
i will post an availability schedule in a longer poste ... later.
Sedgwood tried out Charlie's lackender hoe and the next day pt's version of a simulator make. well, he went with the pt backhoe .. his reasons were under other more speed in the curling action, compared to the lackender version. he is on his long way back to new York state via west Virginia scenic route .. a post is surely forthcoming.
Charlie is the proud owner of a new To...... Attachment. i know you will hear about it after he has done his civic duties ... what a suspense ... right?!?!?!?!
i learned allot, got to speak to the powers to be on the engineering side. we have some answers and some of the others will be forthcoming in the near future.
for #$98.00 i bought a new muffler made by pt for the 25 hp Kohler engine ...what a tank and by the way half of the internet wholesale price of Kohlers commercial version.
tried out a 4:1 bucket and liked the lightness, agility and responsiveness to level, spread and pickup various size of modified stock. the 4:1 bucket i tried is for the 1400 and 1800 series, we in the 400 series will have to wait for some weeks to get an availability date.
Ms. Wendy, Shawn, Terry, Don, Mike, Chris and all the others at pt have made our visit worthwhile, interesting and enlightening.
Wish You All Were There! Do you get my Swiss-Southern Drawl i picked up?!?!?
hrl
/ Another lackender order placed #59
Re: NEWS FLASH ... PT HQ .. VISIT ... NEWS FLASH ONLY
Hans,
Thanks for the update, sounds like you guys are having a ball. Very interesting your comments and Sedgwoods regarding the PT hoe.
It has been quite here on the PT forum with you guys gone.
PJ
had calcium filled tires!
we saw in the rebuilt shop a pt425 whos owners have elected to add this stuff. all it did is damage the protective casing around the openings of the rear wheels and in addition damaged the hydraulic motors ...
for the ones that have not visited tazwell ... the land for the most part is very steep and the people at pt and their local customers are very savvy about working on steep hillside. i also add my two cents to it. <font color=red>had calcium filled tires </font color=red> only on tractors with big backwheels are making a difference ... we in Switzerland with very steep hills never use these means to keep hillside small machinery operating more efficient. Dual tires ...YES... rebarb auxiliary dual wheels ... YES.
i wish there would be a solution other than buying an 1800 series hillside pt mower. at this time we are stuck with what we got in the 400 series, Ms. Wendy will check into what the status, with an answer to the hillside front wheel rising when mowing, is and give us an appropriate response in the very near future ... she said.
for the rearing of the backside of the pt400 series, i have to agree with Mr. m.r. we add weight to the back and the hydraulic capability can lift at least 800 pounds (and then some). Yes ... Charlie or i can add weights to the back ... the vicious cycle never ends and the following forward or back is accentuated and borders rather dangerous situation on uneven ground. let alone that the articulation in this adding weight to the back is going to take the major brunt of the seesaw action and is very expensive to replace.
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
135 (A64278)
135 (A64278)
1995 VOLVO BM A25C WATER TRUCK (A65053)
1995 VOLVO BM A25C...
