rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,699
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Good idea about extended warranty on emissions related items. I'll check with dealer.
While you are there you and he might want to get on the same page on a couple of other warranty issues that come up. One thing already mentioned is who pays for hauling the tractor for warranty issues.
Most dealerships in rural areas have a field service truck so that hauling isn't necessary for most things. Ask about that....
Then there is the issue of just how long a warranty lasts. Like MHarryE says, the duration might be different for emission devices.
There's also a difference between the machine warranty and parts warranty. The overall tractor has a warranty period, but so do any parts replaced. The warranty on replacement parts or any warranty work typically starts for those parts and that work when the repair is made. So the warranty on repairs done is longer than the original warranty. A replacement part warranty doesn't run out just because the general tractor warranty is up.
That should also hold for any issue that is attended to under the warranty period. That issue still needs to be fixed even after the the warranty period is up - as long as the problem was identified and agreed on within the warranty period.
And finally, keep a record of downtime. If the tractor isn't usable for a month, that month should be added to the warranty period.
These are all things that should be discussed, noted, and initialed right on the sales contract when buying any new tractor - it would save a lot of misunderstanding.
But if that didn't happen, now is still a good time to sit down and decide exactly who is responsible for what. At the dealership I was always amazed that more people didn't do go through the responsibilities of both seller and buyer as a normal part of doing business. It just makes sense.
rScotty
