2016 Kubota SVL 95-2s DPF, SCR /DEF Emulator????
   / 2016 Kubota SVL 95-2s DPF, SCR /DEF Emulator???? #1
PAPPASMURF
JACKSONVILLE, AL
2011 KUBOTA L3200 W/ LOADER, BH77 BACKHOE
Need advice on the best Emulator (DEF DELETE) for my 2016 SVL 95-2s. Before You comment, please understand I know about the laws, environment, warranty, and other issues that revolve around the emissions "tampering" so please dont lecture me on that. This skid steer is a beast, but its out of warranty and the DEF system is nothing more than a ridiculous Plethora of codes being thrown and putting me out of work because of going into "limp mode" all the time. I tried having it fixed and re-programmed by Kubota numerous times (Def tube failure, EGT sensor, NOX sensor, ect....) and after thousands of dollars in repairs I'm fed up with the DEF constantly causing problems, down time, and loss of jobs. This may not be a popular choice to some, but if you havent owned one of these you have no idea how problematic they are....all because of DEF systems! Does anyone have a good resource or recommendation for a Emulator that will bypass this system. so far, I have found one for $1,750 with a two year warranty through 4dpf.com. Just wondering if there is anyone on here that has done this, or has a recommendation for a good Emulator to finally give me some relief.
   / 2016 Kubota SVL 95-2s DPF, SCR /DEF Emulator???? #2
I'll look when I get home for who did the 2018 svl95-2s, I remember they are from Canada. But I'll get you the name.
10-4, Thanks. It's probably CAMBUS ?
   / 2016 Kubota SVL 95-2s DPF, SCR /DEF Emulator???? #4
Reimertuning.com
I can't speak for others because this is the only one I used but I haven't had any issues and it's way stronger.
Reimertuning.com
Thank you, Ill check them out.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
SWICT 88" SKID STEER BUCKET (A60430)
SWICT 88" SKID...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2023 VIRNIG RBV50-72" HYD ROTARY BRUSH (A60429)
2023 VIRNIG...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
