Trans pickup screen is open on both ends IE it's is cylindrical shaped.
Which coupling hose did you disconnect to determine that trans pump stopped pumping?
Did you adjust stand-by pressure to 2250 psi after re-installing SC valve?
Have you checked hyd filter relief valve to be sure it's seating?
Does tractor have a FEL? If so what type valve controls it & how are hyd's attached to hyd system?
Thanks for responding Jim,
Josh speaks highly of you!
So, yes I did finally understand the pickup screen after visiting a JD dealersip. Bought a new one and trans filter.
Upon removing it found it almost full with dark granulary particles, a few larger dark particles and some tan vafer like chips. When cleaning the orrifice, I found a nylon piece that looks like it was once part of something with screw or bolt.
Everything worked good (grading box, no FEL) for 3 hours and then it started again.
So I took it apart again and found only small amount of particles this time.
Put it back togeter, worked about an hour and quit again.
When proving that the rear pump was not working after a period of time (10 min then), I disconnected the line without the check valve in it in the bottom of tranny.. Checked the check valve line first and reallized nothing could come out of tranny from that one.
I dont know where the hydraulic filter relief valve would be?
I did not check the pressure with a guage at the front pump but will soon!
Thanks for your thoughts!
Gary
