Another home made cab tread
/ Another home made cab tread #41
I always get in on one side... but sometimes it is the right and sometimes the left. :laughing: ;)
@GPintheMitten
I would be SCARED !!! If you can get in on both sides at the same time, hehehehe :D
LMAO @ GPintheMitten
/ Another home made cab tread #42
I always get off the left side, cause my clothes usually end up getting caught in the joystick, but yes, i must confesse, it should have 2 doors:laughing: I plan on removing it this spring and do a few mods, things i didn't think of before.
Can I add something else to your Spring Projects?
Why don't you get a Car Windshield Washer Pump? That way you can wash your front Window with that nice Wiper. It's cheap on Ebay $18 Pump and some Cheap Windshield Fluids and Wires, and a Switch and you are good to go :thumbsup::D
What i have been thinking to change on my cab;)
- Adding a right side door, not that i will enter from that side, but just to access the joystick and 3pt levers
- rear side opening windows.
- Move the switch board location to the right side, just above the fender.
- Make ducts on the heater so i don't get cold feet.
- Remove that ugly lexan on the front and install a nice sheet of metal.
- Windshield washer
Well that's what i can think of now:laughing::D any suggestions are welcomed:thumbsup:
Hey Karl, FWIW, I never use the right door on my M5040 and have never missed having right hand door on the cab I built for my L3000DT.
Was interested in your comment about the sound level being bearable in your new cab. My L3000DT is very loud to the point I simply wear ear muffs with a built in radio.
Does your Kiota have sound deadening from the factory on the floor boards and cowl?
Anyway, congrats on a very nice job, was interesting following your build. Regards, Roy
Thanks for the comments Roy. Now to answer a few questions:D My tractor is not HST, so the engine isn't always at 2500rpm. When traveling at road speeds the R1 tires make more noise than the engine/ tranny itself. I have the cab pre-wired for the radio, but waited to try it out before installing it. If it was too noisy, no use having a radio.:(
For the floor i did use some 1/2 inch rubber mat, installed over the metal floor board.
The cowl is left as it was from the factory, although i will later (this spring) i will add some of the material i used for the top.
1997 International 4700 Bucket/Chip Truck, VIN # 1HTSCAAP2VH489823 (A61165)
1997 International...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
John Deere XUV825E (A61307)
John Deere XUV825E...
Kubota M4700 (A60462)
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
JOHN DEERE 6700 SPRAYER TOW BAR (A62131)
JOHN DEERE 6700...
