Another Boxblade Question
/ Another Boxblade Question #1
Atch4115
Harrisonburg,VA.
JD 4115
Looking at TSC boxblades for my 4115 they have a 48" and 60". My question is how important is it for the type of work you would use the boxblade for to cover your tracks?I am mostly just leveling small areas in an established lawn.If the only advantage of a wider blade is production I'll buy the 48" in favor of more seat time.The rear of my 4115 is about 52" wide.Thanks for any and all comments.
/ Another Boxblade Question #3
I would go further than just cover your tracks. If your box blade is a few inches wider that your tracks, you can get close to a building, a tree or whatever and still use it. If it is not as wide as your tracks you are limited in what you can do and will always have tracks that you can't cover.
Bill
/ Another Boxblade Question #4
Go with the 60" wide box. It will allow you to grade closer to buildings and obstacles . And if you use it to push snow or dirt backwards your rear wheels will be in the graded area .
If you have R-1/Ag tires now and change to R-4/industrial tires in the future the 60"scraper box will be very close in width to the wider R-4 tires .
Big Al
/ Another Boxblade Question #5
My rear tires are 53" wide, maybe a little less at the contact patch.
I am glad I got a 60" box blade and would not want anything less. Add my vote to the "get wider" side. /forums/images/graemlins/smile.gif
/ Another Boxblade Question #6
If you are going for a 'drug smooth finish' a box small er than your tracks will never produce it.. your overlap will always leave tire marks on each side. Most tractors can tote and pull a box big enough to cover their tracks, and that's what i would get.. unless you stumbled on a super deal used.. like 50-100$.. etc.
Soundguy
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
Mini Universal Forks (A65640)
Mini Universal...
