Annoying Add Banner on Right Side of Page
   / Annoying Add Banner on Right Side of Page #41
Puffin browser white column is not visible at first glance, but if I use the touch screen to scroll on the iPad, the whole page can be bounced around and I can slide the text off to the left and the white column appears on the right.
   / Annoying Add Banner on Right Side of Page #42
Thanks Muhammad working fine after reboot
   / Annoying Add Banner on Right Side of Page #43
Muhammad,
This is iPad specific info that I'm giving, using Safari browser....
I can be sitting reading a page, out of the blue, the page shifts smaller and to the left and about a 1" column of white appears down the right side. Then, several minutes later, the page shifts even smaller and even further to the left and the column of white gets even larger. Then, several minutes later, the columns goes away, the page shifts back to original size and takes up the entire screen.
It's as if it is wanting to load a long, vertical ad space in the right, then a few minutes later, it's trying to load another, wider ad space to the left of the first ad space. Then both ad spaces go away and everything shifts back to full screen.
Hope that helps trouble shoot it. :thumbsup:
   / Annoying Add Banner on Right Side of Page #44
MossRoad I assume you're using the full site version?
I'll check it out on an iPad.
   / Annoying Add Banner on Right Side of Page #49
I dont have problem anymore. Thanks
   / Annoying Add Banner on Right Side of Page #50
I'm using Opera and Apple Mojave 10.14.4. The problem has been resolved for me.
5004 (A55851)
5004 (A55851)
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
HYD AUGER W/ 16" BIT (A52708)
HYD AUGER W/ 16"...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2014 International Derrick Digger Truck (A55973)
2014 International...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
