Posthole Digger Angled Post Holes
/ Angled Post Holes #1
VictorIdaho
Caldwell
none
Is it possible to use the 3PH auger on my 2032r to drill an angled post hole? I need to install vineyard end posts 35 deg off vertical.
/ Angled Post Holes #2
A pint of Jack Daniels Old Number 7 before starting should make it a certainty.:proposetoast: It's difficult to make angled holes without wallowing them out. Look at methods of building fence braceing then adapt one that look's good to you. My fav is driven T-posts and brace post kit from Tractor Supply Company. It's fast and look's nice in a vineyard.
/ Angled Post Holes #3
My favorite method for boring angled holes is to try to drill a straight one! Seriously, folks, the cheap 3-point augers are harder to use than hand-held power augers when it comes to putting a hole in straight, or any angle.
/ Angled Post Holes #4
I've done it fine. Start straight for about a foot the drive tractor forward for desired angle then proceed. May need to back the tractor up to get desired depth.
/ Angled Post Holes #5
The way I put my end posts in, was to dig a larger than needed hole straight down. When you pull the post back so it hits the rim, you will have your angle. Once you find the correct diameter hole, all post will be lined up perfectly.
On another note, I waited a few weeks before adding the support wires, allowing the end post fill to settle and harden. Also, you can use a gas powered one man post hole digger to sink the anchors, saves a lot of hard labor.
/ Angled Post Holes #6
Yeah, as others have already said, most of mine came out angled. I would think you could intentionally angle it as you want by being in-line with the angle. The auger is free to pivot front/back but not so much side to side.
/ Angled Post Holes #7
I have to be very careful to keep from drilling angled post holes and even then, they don't all come out that way. I'm not sure about 35° though.
/ Angled Post Holes #9
Yet another example of DRIVING your endposts
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
