Andrew Camarata
/ Andrew Camarata #561
He usually dives right into the repairs and gets it done without sitting around whining about it. Doing the best quality repairs for equipment that’s not on a job earning money isn’t really an option. It would cost hundreds of thousands of dollars per year to keep a fleet of equipment the size of his properly maintained.
I often wonder how he keeps the batteries from going bad in machinery he won't get back to for a year at a time.
/ Andrew Camarata #562
You see him putting multiple chargers on equipment at times and he is very liberal with ether . . .
/ Andrew Camarata #564
Nearly every video involves his Honda generator and a battery charger.
/ Andrew Camarata #565
From that information, I reason that Matthew's most used machines have well maintained batteries and the rest get the Honda generator and battery charger treatment. That would probably be the most economical plan for engines a sit idle for so long.
/ Andrew Camarata #566
My favorite Andrew Camarata episode is the one where he tells how got started in excavation.
What's yours?
/ Andrew Camarata
Cutting his dash with a chainsaw to install a radio... laugh my butt off as he did it and again at the stupid comments and reactions that followed...
He gets things done, no matter what it takes...
/ Andrew Camarata #568
That recent shed video is funny, he does a nice job and it's a fairly large building, but he still only gets a couple pieces of equipment in it. Then turns around at the end to pan across the 25 machines "really, none of this should be outside". Good luck with that idea, Andrew, haha.
/ Andrew Camarata #569
Well over a 4 hour video so lots of FF.
At 1:05:45 he's showing his new punch tool. WE had a stand alone unit at the plant every called the ironworker. Worked great until you got the dies slightly off then snap.
/ Andrew Camarata
I don't know if you follow his "B" rated videos under his "playlist" but old Andrew said that he is expecting a son... he was fixing up a house in town.
PS. 4 almost 5 hours is way too long, good content but had to fast forward through most of it....
/ Andrew Camarata #571
Thanks for the heads up, I just skimmed through that video. Someone asked about the dogs and he said they are 1000 miles away so I assume she does not live in his state.
/ Andrew Camarata #572
Don't put Bjoernstroem in the same class as A.C. A.C. is a hack who get lots of views cause of his shot with his dogs and land scapes not at all for good work. Everything he does is a "How Not To" video.
Bjoerstroem is a legit operator, mechanic and carries a blasting license. He made the rock crusher himself. I would hire him in a minute. I wouldn't let A.C. take out my garbage. 🍻
But yet here you are fishing for comments on a specific only to Andrew Camarata Thread...
/ Andrew Camarata #574
Not fishing. Making a statement.
/ Andrew Camarata #575
Today's upload I thought he was going to slide all the way down and flip with that firewood shed on the tracked mini dump truck. The dogs were also pretty entertaining today.
/ Andrew Camarata #576
AC does many things well and some things not so well. I don’t think he has EVER said “I’m an expert.” He also takes on a lot himself and learns from it. He’s also called in help and brought in other pros for things he can’t do.
/ Andrew Camarata #577
He has matured a lot, but can still be pretty reckless. I wouldn't have had anyone in the shed while moving it, and would have gotten them out immediately when traction became questionable. I also would have stopped trying after slipping the second time.
I put those studs on my excavator tracks last year and they definitely help. Tracks are otherwise like ice skates when it gets slick.
/ Andrew Camarata #578
I thought it was funny he ordered a 10' shed and got a 12'. As he said, it was nice but he already poured the slab for a 10 footer. :ROFLMAO:
I see he's got a son now. No mention of marriage that I heard. The "new girl" was no where to be seen for a long time. And I don't know if she's the one that popped up in videos from afar occasionally. She was mostly behind the camera. I watch him mainly for his "fixes" but at times, it gets on my nerves that a millionaire still does farm engineering. ;)
PORTA POTTY (A68842)
2022 Landmaster L4 (A64912)
2022 Landmaster L4...
1994 GREAT DANE 48' T/A DRY VAN TRAILER (A67714)
1994 GREAT DANE...
PALLET OF MISC TRAILER PARTS (A68842)
PALLET OF MISC...
(2) Hakkapelitta 360/80R28 Tires & Rims (A64911)
(2) Hakkapelitta...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
