Grapple Anbo Grapple Rake
   / Anbo Grapple Rake
I thought of that too. That's the way the set it up, but I haven't used it yet. You've reminded me to make a note to change that the next time I'm out there.
   / Anbo Grapple Rake #12
You'll love it! I have a 72" AnBo, it works great and is built rock solid. Enjoy!
Craig
   / Anbo Grapple Rake #13
How do you like your anbo now. I am thinking of purchasing a 72. Or possibly the bodozer.
   / Anbo Grapple Rake #14
I got the 72" light version ANBO and love it. Picking boulders, clearing brush, moving logs. Very well made.
   / Anbo Grapple Rake #15
Thanks. I am looking at the standard duty 72inch. From all my research it seems to be a very well made grapple.
   / Anbo Grapple Rake #16
Very well made, very expensive, very heavy and not indestructible. Of note, there have only been a few reports of significant damage to grapples on this board over the past couple of years and at least one ?2 were related to Anbo grapples. One guy twisted the top arm while trying to pull a log. Don't recall the specifics of the other (including whether it was an Anbo or another clam shell grapple). One report of a problem doesn't count for too much except that it was notable that Anbo refused to fix it. It is also notable in that the Anbo is sold as the roughest toughest etc but the damage occurred in a pretty routine use and would not have occurred with a simple single arm grapple. The Achilles heel of the clam shell grapples seems to be that trying to clamp on an asymmetric load which can apparently twist the upper arm frame.
Think hard before you invest in a $3000 grapple because there are not many tasks that cannot be done with one costing much closer to $1000. WRLong and a few other companies sell basic root grapples that seem to function just as well as the uber engineered $3000 types.
   / Anbo Grapple Rake #17
Do You remember what forum The anbo that had been twisted was in? My dealer priced the Wr long 72 grapple in the high twos. It would seem the way the clam shell is designed that it would be easier to push up against the brush or logs and then clamp down on it and tilt up. Is the open bucket design harder to slide under an object?
   / Anbo Grapple Rake #19
I just bought a millonzi grapple,,,$1000, 48 inch,,,,,works great on the front of my DK45se. Absolutely amazed at how well it works. It does not over power the tractor. The quick attach does limit the tilt back power but I see it as a safety factor. Knocked over some big trees,,,8 to 10 inch in diameter. Then just ripped out the roots a little at a time. Picked up trees 30 feet in length. Biggest problem is fitting between the trees along the road. Had to cut them shorter. I cannot see buying a bigger grapple and I am glad I did not. The 66 inch was the next size up the supplier had, looked alot heavier and would have needed to be on a bobcat or very large tractor. My brush pile is growing fast,,,gonna be a big burn this winter. Best thing I bought,,,why wrassle when you can grapple.
   / Anbo Grapple Rake #20
Sorry, I don't recall specifically but I'm sure a little search work would locate the post.
The clam shells are nice for picking up smaller debris. However, the more "traditional" root grapple like the one in my avatar do very well with brush and logs and rocks. Indeed, I think the clamshell has some disadvantages when going after rocks and larger objects because the only thing holding the object in place is the clamp pressure while with the traditional grapples you really cradle the object(s) in the bottom and just use the upper clamp to hold them from falling out when you are moving. Kinda like the difference between picking up an object with two fingers vs placing it in your palm to lift and carry. The clamshells also have a bit harder time leveraging things out of the ground as they have shorter more vertical bottom tines so you cannot get as good leverage. Finally, they have a shorter reach with the bottom tines so you will find it harder to get under the roots of a bush or tree to pop it out of the ground intact.
Intact brush as in bushes and small trees are easy for both types of grapples. The clamshell has an advantage in "pick up sticks" but I don't find that is such a common task. If the "sticks" are a couple of feet or more long then there is no particular advantage for the clamshell. A clamshell can be more efficient than a single upper jaw grapple in scooping up large numbers of sticks spread around an area rather than piled too.
Whichever type you get, don't get one as wide as your primary bucket. That is a common misconception. Narrower grapples weigh less so leave you with more payload capacity. I can lift a lot more with my 280lb Millonzi 48 inch light duty grapple than I could if I had a 800lb Anbo. The narrower the grapple the more force you can apply to an area of root, rock etc while breaking out and the narrow grapples are always lighter than their wider cousins. A wide clamshell is more vulnerable to the sort of torquing of the upper arm with an asymmetric load that I described in the earlier post. It goes without saying that a narrower grapple is cheaper too.
Dealers and even manufacturers (maybe excepting WRLong) don't always have much experience using grapples on CUTs so they tend to give pretty generic advice. If you have a big skidsteer then a big wide grapple is probably appropriate especially if you are trying to clean up construction sites. The manufacturers generally rate the grapples for skidsteers in commercial use rather than for CUTs and IMO they underrate their smaller grapples. Even WRLong does that. For most CUT users however a smaller lighter grapple is best. If your tractor has a 200lb standard bucket that doesn't break why do you need an 800lb high tensile steel grapple?
  • Good Post
Reactions: fc1
GODWIN 3,500 PSI HYD. POWER PACK (A55745)
GODWIN 3,500 PSI...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
