Analog to Digital?
/ Analog to Digital? #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
I would like to take a cassette tape and get the infomation on it onto my computers hard drive. How can this be done other then by a microphone? Thanks in advance, Rat
/ Analog to Digital? #2
Analog -> Analog –> Digital…
Cable out from Cassette OUT 3.5 mm jack TO -> Computer Auxiliary IN 3.5 mm jack
Start your favorite “record” program on computer, start your play on external cassette
When complete, save file on computer as “wav” or other selected format… you can later convert “wav” to mp3…
/ Analog to Digital? #3
Radio Shack sells a cable that goes between the output jacks on a cassette deck into the input jack on a sound card. I do this all the time. You will need software that record off the input from the sound card. CoolEdit 2000 works well.
/ Analog to Digital? #5
Wait a minute here, you did not specify if you are using a low-level output of the cassette unit or a headphone jack output. You attempt to try that if the output is not compatable to the input of your soundcard in the computer, you'll get nothing but a garbled mess.
J.W.
/ Analog to Digital? #6
<font color="blue">or a headphone jack output. </font>
Um, er, neither John nor I mentioned using the headphone jack. /forums/images/graemlins/smile.gif
/ Analog to Digital? #8
I use a portable (walkman style) mp3 cd player and it has 2 outputs one for a cassete adapter or of course the headphones and either works... I just have to turn the volume down low to prevent noise if using the headphone jack...
in this case of course the casset adapter is translating...
Or are you folks talking about ( for example) The output, like you find on upper end car audio that goes out to an amp? Same concept?
Just curious....
I've considering doing the same thing with some of my old favorite cassetes.
/ Analog to Digital? #9
<font color="blue"> The output, like you find on upper end car audio that goes out to an amp? Same concept? </font>
I was referring to a home cassette deck that has stereo input and and stereo output jacks.
/ Analog to Digital? #10
Call up Bill Gates and ask him. I think he only charges $1,000,000,000 a minute /forums/images/graemlins/crazy.gif....... I think the other posts should get you started. Good luck.
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2015 GENIE S-60 MANLIFT (A63569)
2015 GENIE S-60...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 FORD F-250 SUPER DUTY (A63569)
2008 FORD F-250...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
