An Old Guy Project
/ An Old Guy Project #1
Little Red Tractor
Platinum Member
Gloversville NY
Kubota 2301
Took on a project.
With a couple hundred feed of stone driveway to rid of weeds two or three times each year, I was getting tired of the seven or eight trips it took with the two gallons hand-pump srayer. So, last year, I picked up a 15 gallon electrip sprayer made for ATVs...but I have no ATV. With the winter to think about it, and a local machine shop that lets me rummage through his pile of leftover steel, I set about to build a 3 point-mounted rack. For a guy who doesn't weld enough to say so, and deals with essential tremmors to boot, it didn't come out too bad. A couple pretty ratty welds; a couple mis-mounted pieces...but it went together pretty well. I should have staged the pictures better; but oh, well.
/ An Old Guy Project #3
Took on a project.
View attachment 866755View attachment 866756
Looks good to me. I have had a 15 gal Star sprayer from Northern Equipment for many many years. I carry it in the cargo bed (box) on the golf cart.
Last yr I bought a bigger 26 gal tank and plan to build a similar 3pt hitch rack for the Kubota like you have done. So far no other progress - I am planning to build a 3pt receiver hitch. Then just make a tank carrier that is hitch compatible. This way I could make other hitch compatible things to use with the hitch.
/ An Old Guy Project #4
That 15 gallon tank has the indentations on the sides for a reason. Many smaller 3 point lift arms slide/snap into those indentations tightly. Adding a strap or bungee can hold them tightly in place. I know I can snap a small tank like that into place on my little Deere while it wouldn't work on heavier lift arms. Never tried it on a Kubota.
/ An Old Guy Project #5
Very nice! Mounting the tank to the tractor is much more user-friendly than having wheels ono the tank to tow it. After jack knifing my tow behind spray tank and cracking the plastic tank, I built a sprayer using your approach.
BTW - old guys have the gift of years of experience
/ An Old Guy Project #6
That’s very nice. For my 20 gallon sprayer, I use a 3ph carryall and mount a pallet on it for the sprayer and battery.
Here's an update on my project:
After finally getting a bit of weather in which I could do my spraying, I hooked the unit on the tractor, put some water in the tank and fired it up--NOTHING. Well, the pump motor ran, but nothing came out. I double checked the polarity on my connections just to be safe--not a problem there. To make a long story much shorter, I figured it was a problem in the valve that actually allowed the pump to connect to the motor. I took off the end cap and attempted to disassemble the motor/pump connection without being able to do so. HOWEVER, I found that there is a screw unter the end cap that seems to put pressure on the controlling component of the valve. It appears to have been stuck in a closed position. I reassembled the mess and tried again...I got a trickle, but no pressure. I put a bit of air pressure on the supply sid of the pump and "something" opened up. After reconnecting the hose, it worked fine, though I suspect I'm putting out a bit more pressure than it was originally inteded for--It's OK, I'll keep it!
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
