Amps formula??
   / Amps formula?? #1
dthomas
Newton, Mississippi
New Holland 1720
I would like to figure how many lights I can safely run at one time. What is the formula for figuring amps based on wattage? /w3tcompact/icons/crazy.gif
   / Amps formula?? #3
Voltage times the current. 12w (watts) is equal to 12 volts drawing 1 amp. A 60w light would draw 5 amps.
Keep the greasy side down.
Mike
   / Amps formula?? #5
I'll add an example (I always needed examples to let me see the light (bad pun intended))
if you wanted to add 5 100W bulbs to a 12V system, this would require
500W = 12Volts X XAmps
X amps = 500W / 12 Volts
X = 41.66 Amps
(lets hope that you do not need 5 100 W lights/w3tcompact/icons/smile.gif)
rf33
/w3tcompact/icons/wink.gif
   / Amps formula??
Thanks to everyone for the help. I have already added two 50 watt lights and was wondering about running them and the orignal headlights all at once. Since the alternator is rated at 35 amps, I should be alright. Kevin, thanks for the links. Now I will make a spreadsheet application so I will not forget. /w3tcompact/icons/smile.gif
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
Genie GTH-644 (A50490)
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
7022 (A50322)
7022 (A50322)
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
UNUSED FUTURE SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE SKID...
