Amazing wood chopper
   / Amazing wood chopper #3
I'd really like to see the mechanism inside. Interesting.
   / Amazing wood chopper #4
It might look a little like this.
2457891310
   / Amazing wood chopper #5
Interesting would be useful if the length can be adjusted to 16-18"
Yep, needs longer length, who wants to feed a wood stove with 6" blocks + other than northern Canada where most of the trees are less than 8" in diameter with most being like shown it the video, where would you get all those little 4" saplings. I wonder how well it would chop hardwood as compared to that pine.
   / Amazing wood chopper #6
It's cool. 12-14 inches and 4" diameter is ideal for my stove. What he is making would be great for cook stoves.
I have lots of maple and ash saplings with clear stems. If I could chop those that fast it would be great. I think the overall productivity would be low if someone had to de-branch the stems first.
   / Amazing wood chopper #7
follow the videos down on the right on youtube there are better ones
   / Amazing wood chopper #8
Another video showing the insides of one of the models.
R
   / Amazing wood chopper #9
Thanks J_J. It looks like the length of wood cut is a function of the diameter of, and number of choppers on, the cutting wheels.
   / Amazing wood chopper #10
According to the videos, the pto on those tractors turns counter clock wise.... I don't know how fast...
Even on the chippers that look home made there is a lot of good engineering and quality machining that has
gone into the building of those machines...
I don't heat with wood, but suppose a fire box monitored by a thermostat and good damper controls would
make that size wood burn as efficiently as any other...
Good engineering and work.....
   / Amazing wood chopper #11
R
Here is a video of the kind of chipper shown in reply post #4.....
It appears it make a course type of landscape style mulch/chip product...
I have seen both wood heaters and outside boilers that use a fuel product
like this that is augured to the fire box from about a 2 cubic yard hopper...
Looks like a good system, if you have the need for that size unit...
Good luck
   / Amazing wood chopper #12
that would have been great to have years ago when i burned wood.
   / Amazing wood chopper #13
I ran into these things a couple of years back when I was wondering about making a chipper: I'm pretty sure that they're cutting the wood for "Wood Gas" or "Bio Gassification". The idea is to pack a load of wood into an airtight burner - where it burns in a low-oxygen environment and produces flammable gas. You can even run cars on it.
Build A Gasifier - What is Available
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A60432)
ANTHONY CARTS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
FUEL TANK (A60429)
FUEL TANK (A60429)
SKID STEER LAND LEVELER (A60430)
SKID STEER LAND...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Caterpillar 906M (A53317)
Caterpillar 906M...
