Am I the only one with this problem?
   / Am I the only one with this problem? #1
Iowachild
NW PA
Kubota B2320HST
For years I have used Netscape browsers. Then sometime after this site up-dated I found I could not use the buttons (smilies, fonts, insert link, etc.). I then downloaded Firefox 1.0.7 and everything worked fine. Now the buttons have stopped working on Firefox. As with Netscape I can type in the box and make a post, but not with any of the features. In order to use the buttons I have to open IE. Has anyone else experienced this?:confused:
BTW TBN is the only posting site I visit so I cannot say whether or not the problem exists on other sites.
   / Am I the only one with this problem? #2
Works fine for me with Firefox...my guess is, your editor account settings need a tweak.
Click here to get to your account options.
Scroll to the bottom, and make sure the "Message Editor Interface" option is not set to "Basic Editor" - either of the other two will give you the options you are looking for. I use the "Standard Editor", as the "Enhanced" option is a little bloated and flakey for my tastes...
   / Am I the only one with this problem? #3
Replying from Firefox 1.5.0.7:)
:eek:
:p
:rolleyes:
and, I even discovered
that there are indent icons
  • bullets
  • and more bullets
  1. or numbers
  2. and more numbers
One can even right justify:cool:
center:confused:
or be a a left justify kind of personality:p
GOSH!! I MAY NEVER STOP PLAYING WITH THE EDITING FEATURES.
SEEMS THERE is all too much power in the editor... never will get any work done now:eek:
   / Am I the only one with this problem? #4
Hmm... Mike, have you updated to the latest version of Firefox? I would recommend getting the latest of whichever is your favorite browser.
I know some of the features use more "modern" features that might not be in older browsers. But you should be able to go to the "basic" posting options. But I would recommend getting the latest browser version.
-Ibrahim
-Ibrahim
Ibrahim,
I noticed Texasjohn stated he was using Firefox 1.5.0.7. So I up-dated and now it seems to be OK.:D
However, everything did work when I first started using the older Firefox. That's what I don't understand!:eek:
   / Am I the only one with this problem? #6
I stopped using FireFox due to problems when downloading/viewing PDF files. Too often the computer would freeze.
I have tried several times to use FireFox - different versions, including the very latest - but to no avail. I still have problems.
So, I am back to using IE. But, I have added a little program called AdMuncher. The latter takes out the ads the same as FireFox.
   / Am I the only one with this problem? #7
Iowachild, hate to tell you... a computer is like a woman.... just about the time you figure everything is working fine, something happens:confused:
And, if you think that you can understand what happened, you got another think coming:rolleyes:
Just count your blessings if you are able to fiddle around a bit and get things going OK again:D
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
BESTWAY AG VSK50 LOT IDENTIFIER 96 (A53084)
BESTWAY AG VSK50...
