am I missing something here?
   / am I missing something here? #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
there is a guy selling these "log splitters" on craigslist...
Log Splitter
How are these supposed to split a log?
   / am I missing something here? #2
Oh
they work well...
All you have to do is add one or two additional parts.
An engine.
A hydraulic pump
A ram.
A few hoses.
Other than that, they're mostly complete.
but the parts are welded solid... nothing moves!
   / am I missing something here? #4
They were the ones built on friday afternoon, the assembly team didn't quite grasp the concept! LOL Maybe they were lawn art?
   / am I missing something here? #5
The blade is often fixed on the log splitters.
You would need something to connect your ram to.
And, assuing you're splitting about a 16" piece of wood, you would need about a 16" ram, plus a few inches for the ends. So, one would need the bed to be at least 3' long, perhaps a bit more.
The I-Beam would make a good guide for the ram.
Perhaps these were working machines that were stripped, but more than likely, an unfinished homebuilt project with some serious design flaws.
The steel is probably worth at least $50 for the pair. But, unless you already have the parts, or are planning to use tractor hydraulics, the build will be expensive.
   / am I missing something here? #6
Designed by our friends at OSHA so that there is no way to pinch your fingers between the foot and the wedge.
   / am I missing something here? #7
:laughing::thumbsup:
   / am I missing something here? #8
I have seen one like this before. You use a bottle jack to split your wood. Very slow process if you have more than 4-5 pieces to split.
   / am I missing something here? #9
I'm with you Mike, I seem to be missing something too. It looks to be well used after painted but how it was used is beyond you n me I guess.
   / am I missing something here? #10
That would work. A bit clumsy. Better have an air powered hydraulic bottle jack with spring return.
Otherwise, I would wonder if an axe and a maul would be less work. Perhaps give the kids the bottle jack while the older people use the maul.
   / am I missing something here? #11
1. Place log between flat and pointy parts, resting against pointy part.
2. Wrap bungee cord around log and I-beam.
3. Tip I-beam on end, pointy end down.
4. Climb a very tall tree with above assembly strapped to your back.
5. Drop assembly from tree, with pointy end down.
6. Climb down (or fall - fall = quicker, climb is a bit less painful.
7. If successful, repeat with new log - if not, place OTHER end of log on pointy part.
8. Repeat from (2.)
9. Bring a large lunch... :D
   / am I missing something here? #12
You guys.... Doncha know nuthing... them is Polish log splitters!:D.... Just kidding.. no Polish persons were injured in the making of this joke...
   / am I missing something here? #13
I'd get the brown one- has axles for wheels!
I bet he sells these!
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
More info coming soon! (A56858)
More info coming...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2008 TOYOTA Camry Solara (A59231)
2008 TOYOTA Camry...
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
