Am I crazy
/ Am I crazy #11
Brokermike said:
Please don't consider this a Massey Specific Question I'd like input from all fronts
I have a new Massey Ferguson GC2310 that I bought in January. I'm considering getting a bigger tractor and need some guidance. It now has 29 hours on it and I'm getting some serious buyers remorse. I recently finished construction on my house but have tons of landscaping to do. I do not need a riding lawn mower, I already have one, I need a tractor to maintain my driveway and 10 acres, including firewood, tree removal, stone wall installation, and brush clearing.
I've found that the backhoe doesn't seem big enough to dig out stumps any bigger than 5-6" and that the tractor seems to move around a ton when I'm using the backhoe. I don't have a ton of experience but I'm getting kind of frustrated. Is this my lack of experience that will get worked out over time?
I've also found the front end to be really light with the backhoe on, making turning very difficult some times.
I've also found that I'm constantly maxing out the front end loader. I've tried stacking pine logs, cleaning out pig pigs and it just groans and won't lift unless I back out and take a much smaller bite. Is there something wrong or am I just asking too much?
In addition I dislike the lack of ground clearance, I can't seem to skid logs out of the woods without getting hung up in ruts, and the approach and departure angles are awful with the backhoe on.
I talked to my local dealer this morning, he wants $19,500 for a new 1529, and doesn't have access to a 1528. He will only give me $14,000 trade in on my GC2310. Please keep in mind that when I bought mine in January I also brought in my brother who bought one also, we paid $16,400 a piece. I also have a Bro-Tek Thumb and 5ft rear blade that goes with it.
I'm willing to give up a backhoe for a heavier more powerful tractor. Can anyone make some reccomendations here? Am I just jumping the gun or do my needs justify a larger tractor?
I have 10 acres like you, but mine are pasture with a few dozen old almond trees. And, like you, I eventually outgrew my first tractor.
In May 05 I bought a new Kubota B7510HST (21 hp engine, 17 hp pto) with the LA302 FEL (4-ft bucket) on a 0%/36 month deal. It satisfied my needs while the house was being built (landscaping, paver block walkways, patio, sheds, etc).
Now I plan to put 7 acres into hay and need a larger tractor to handle the tilling and the baling. Several weeks ago I traded the 7510 (it was almost paid off) for a Mahindra 5525 (55 hp engine, 45 hp pto) with a gear tranny and a ML250 FEL (6-ft bucket, 2950 lb lift capacity to full height at the pivot pins). The 5525 is a strong, heavy machine (5400 lb without the FEL). The deal was 0%/48 months. With the trade-in, my monthly payments actually dropped by $100.
I also own a nice 1964 MF-135 diesel that will be used for seeding and raking chores.
/ Am I crazy #12
Mike, It sounds like you really are going to benefit from this upgrade, The only other thing I think you might want to consider is going to a 1533 or 1540 which are the same physical size as the 1529 but have the larger more powerful engine...Its easier to have the power and not need it,than to need it and not have it.... 10 acres seems just about "right sized" (corporate term) for a 1533/1540...
The 1529 seems to be somewhat of an Odd model tractor , you don't hear or see much talk about them....ie: not very popular
Good Luck with your decision...;)
/ Am I crazy #13
Mike... I have 11.5 ac here and I looked at a GC2310, but came out with a 1533 and I am sooooo happy I did. IMO you do need a bigger tractor.
VVVV I have some photos of my place in the my Sig below VVVV
/ Am I crazy #14
Sorry Nasty135, but I would like to correct something you wrote.... the 1533/1540 are physically larger than the 1529, I've been looking at both myself over the last few weeks - drove a 1529 and 1531 and sat on a 1533. The 1529 is the same size as the 1528/1531, which are the mid-size chassis, the 1533/1540 are the large size chassis in the Massey compact line.
You don't see much about the 1529 because it hasn't been out long. The dealer told me it's Massey's new equal to the New Holland TC30 - a nice, no frills, relatively inexpensive basic tractor.
Mike, if you can afford the upgrade, get what you want rather than keep something you don't like. I like the 1533 myself - it's got a few nice features you'd probably like over the 1529 (tilt steering wheel, extendable hitch arms, quick adjust stabilizers, smoother ride due to larger tires, more lift capicity and larger engine). The 1533 would be a larger step-up for you also - even more worth making a change.
/ Am I crazy #15
Archy, Ok thanks, When I originally was looking at a brochure for the 1400 series there was a 1429 which appeared to be as large as the 1433 but with the smaller engine...I must be honest and say I didn't actually see that tractor in person and I didn't read any spec's , But the brochure photograph must have had a small man operating it in the picture because his size made the tractor look like the larger 1433 size to me...:eek: I don't like to give bad info , Sorry for the confusion. I assumed this would be the same for the 1529 vs. 1528 & 1531....
But my advice is still the same go for the larger tractor FWIW :rolleyes:
obviously not very much..
/ Am I crazy #16
I just traded up from an Iseki TL2700f to a MF1533...huge difference. Not even worth comparing. We just bought 6 trees from a farm down the road. They were in the range of 500-600lbs each. The guy who sold us the trees had a 29 horse power Yanmar (very similar in size to my old Iseki). When he would pick up the trees his back end became VERY light. I experienced this several times on my old tractor. Unloading the trees with my new MF1533 was a pleasure. Big loadeer easily handled the root balls and the weight. The physical size difference is significant...as is the weight. I would have probably gone larger, but wanted to use my existing 7000lb trailer.
/ Am I crazy #17
I dont mean to lean the other way but, my GC2310 has been great. I use it to move alot of rocks dirt and dig long trenches. I like it because it is small. I looked at bigger tractors and I really do like them but where I need to go go they just wont fit. I guess it depends on what you intentions are for the tractor. If I could I would have one of each but, cant happen.:rolleyes:
/ Am I crazy
any thoughts about an even trade for a Kubota L3400 with 120 hours. I know it's not a Massey but size wise it seems like a good fit????
/ Am I crazy #19
I went through this type of thing a few times with boats and didn't want to do it again with a tractor. Started looking at JD 2305 / MF2310 type equipment BUT purchased JD 3320.
In your case FWIW, I'd skip the 1528/29/31 etc and go straight to 1533. FEL and BH specs are so much more for not that many $$$ more. If you think Mid PTO or Rear SCV's, Power Beyond will ever be needed - order them upfront & it will be less expensive. With JD anyway (not sure about MF) some of these items are "Sales" items not "Parts" and get discontinued as kits if the model is discontinued, so may be very difficult to add a few years down the road.
/ Am I crazy #20
I am going to back the others that have mentioned to make sure you are getting enough tractor. Like sheds, garages, and barns, tractors also seem to fall into the "I thought I had gotten one big enough until I started to use it" category!
I have 25 acres and a 1500' long gravel driveway. A farmer down the road cuts and bales my hay for me (around 7 acres), we plant around 1,000 pumpkin plants per year, and we are in the process of clearing areas for planting 300 Christmas trees per year over the next three years. I have a 1433V and it does farily well but I am dreading the day when my farmer friend (in his 70's now) gives up cutting my hay because I have done it once with my tractor and his equipment and also with his tractor and there is no comparison; his is a 40 hp Ford, 4 cylinder and his gits-er-done much easier than mine! I am waiting and hoping that in a couple more years (when I have a couple other items paid for) that MF offer's their 0% financing for 60 months on the larger of the 1500 series tractors and then I'll make the move.
CFG Industrial H15R (A60463)
CFG Industrial...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
M998 (A55852)
M998 (A55852)
