alternator pully
/ alternator pully #1
mit
does anyone know how to take off the alternator pully? is there a special vice? i tried with a regular vise and i marred the pully.
/ alternator pully #4
I bet your going to need a puller.
/ alternator pully #5
A two or three jaw puller to put a little pressure on the pulley then tap close to shaft with brass drift to make it pop loose. Or put alternator in vise or something to hold in place and put two pry bars under pulley close to shaft and work loose.
Penetrating oil before attempting to remove will help.
/ alternator pully #6
Picture of a puller.
/ alternator pully
thank u all for your responce. i have to remove the nut that is holding the pully. i need the shaft to stay tight so i can turn the nut off with a wrench.
/ alternator pully #8
mit said:
remove the nut that is holding the pulley
Then I stand by my first statement, 1/2 impact.
If not available, steady a box end wrench on the nut and smack the end with a hammer handle. Hard.
Grip the pulley with a twisted rag wrapped around it and a pair of gloves.
/ alternator pully
the rag idea sounds good but i would like to use some kind of clamp that could hold it strong. is there some kind of pully holder?
/ alternator pully
not going to bother to go this way too expensive. the rectifier cost too much from the dealer. might be better to get a rebuilt.making inquiries to get it rebuilt.
