Alternator for B3030
/ Alternator for B3030 #1
Wally01
I'm in the process of purchasing a Kubota B3030 with the 403 loader. I would like members' opinions regarding the necessity to upgrade to the 40 amp alternator. The only additional power needs I will likely have is from the installation of two 55W halogen lights for nighttime snowblowing. Thanks for your help.
/ Alternator for B3030 #2
In the past, one our members mentioned a formula that you could use to determine how many volts your extra lights would require. I do not remember it, but there has been lots of discussion on this subject. You might do a search and see what you come up with. Once you figure out what your lights will require, and what your alternator produces, then you will know if an upgrade is needed.
/ Alternator for B3030 #3
The alternator is only about $175 as a dealer installed option (installation not included). If you plan to add lights it's well worth the money. The two 55w lamps will draw just over 9 amps. If you add another light, or even turn on your headlights along with the 55w lites, you will exceed your stock dynamo's 14 amp output.
/ Alternator for B3030 #4
The formula you are looking for is Watts = Volts x Amps. Plugging in 12 Volts and 14 Amps for the Dynamo gives 12 x 14 = 168 Watts. Two 55 Watt lamps leave 168 - (2 x 55) = 58 Watts. If the headlights use more than 55 Watts then you have a problem. With the 40 Amp alternator you have 480 Watts and after your two 55 Watt lamps you still have 370 Watts available for additional lights and accessories. Also you must remember you will not always be getting the total quoted output from the alternator or dynamo (such as at idle).
The only down side of the alternator upgrade (besides paying for it) is it makes it harder to check the oil.
/ Alternator for B3030 #5
It shouldn't. Mine came with a new dipstick and dipstick tube as part of the installation kit. I have no problems at all checking the oil.
/ Alternator for B3030 #6
The new dipstick that came with the alternator kit I installed on my B7800 is shorter than the original and has no tube (because there is no room for one with the larger alternator). I now have to remove the engine compartment side panel to reach the shorter dipstick under the alternator. But that to me is a very minor inconvenience when weighed against the 40A (vs 14A) charging output of the alternator.
/ Alternator for B3030 #7
Exactly the same as my B3030!
/ Alternator for B3030 #8
I was able to do some very careful bending of the original dipstick to make it fit around the alternator. It can be done and it makes it a lot easier to check the oil. I hated the idea of having to remove the front grill and then the side panel just to do something as simple as checking the oil. I run three 55w work lights and have had no problem. Well worth the cost to me.
/ Alternator for B3030 #9
Toolguy - I must try that. Then I too can have the best of both worlds.:D
/ Alternator for B3030 #10
I think if you are even thinking about adding work lights you should go ahead and get the alternator upgrade and have it installed while it's in the dealer's shop for the pre-delivery prep. I offered to buy the kit and my dealer installed it at no additional charge. My kit didn't come with any extended dipstick or tube and the above is the first I've heard of it. Yep, checking the oil is a little bit of trouble having to open the side cover, but the options that the upgrade alternator offers is worth it.
/ Alternator for B3030 #11
Bottom line? Buy the upgrade whether you need it NOW or not. Ya cant power jack squat with the stock 14 amp thingy. I didnt...wished I had..and would have if I had know about it. Its definately something I intend on adding to mine!
/ Alternator for B3030 #12
May I suggest you rate the alternator for 125% of the load. Put another way the load shouldn't exceed 80% of alternator rating. No need to max it out if you don't have to.
Example: If the load will be 40 amps get an alternator rated at 50 amps.
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A61573)
2014 Hyundai...
2005 Butler pole trailer (A62679)
2005 Butler pole...
