Alternator Belt
   / Alternator Belt #1
Kc8ehd
Hinton Wv
LS XR4040C
Got tractor back from dealer after an hard to start when cold issue , was just getting a loud thump when key was turned , if I could get the engine to turn over it would start ..they replaced glow plugs , fuel relays ECU , don't understand why ? And finely they replaced the starter after 6 weeks the tractor was back , first cold morning "CLICK THUMP" ok sounds like a battery to me , replaced battery with a Napa gold ...and it started right up , now to the vbelt ...cold morning and snow had several tries to get tractor to start , glow plug cycle than crank after 5 or 6 times it starts ... notice smoke coming from under hood shut it down ,found broken fan belt of course had to order belt , anyway replaced belts all was fine weather had warmed up and it started every time all seemed well , weather turn cold again go to start same thing 5 or 6 30 seconds cranks to get tractor started battery light came on smoke coming under hood shut it down ...Alternator belt was smoking ... and melted belt crumbs all over alternator.... ( yes it was tighten to spec with a belt gauge) restarted engine to see what was locked up and it started and ran just fine battery light out fan turning , went ahead and use the tractor for about 2 hours ...question is just what could be causing this , alternator ? Starter shorting ?
I'm at a loss I did buy a spare belt hate to change it before I locate what's causing this.
   / Alternator Belt #2
Could be alt or water pump ?
   / Alternator Belt
That's the only two Fuctions of this belt
Thinking alternator that's where most the burnt rubber was , only does this when a hard load is put on battery , never had this problem until starter was replaced ...( May have nothing to do with it but is a suspect)
   / Alternator Belt #4
Take the alt out have it bench tested , spin the fan by hand to check water pump I blow the alt out with air when I clean the front screen always full of dust maybe the bearings are seizing up when it gets hot
   / Alternator Belt
Water pump free , didn't detect any noise
Alternator spins free also no noise ... Alternator shouldn't get hot when starting engine.
   / Alternator Belt
Not for sure will check , deep green in over flow bottle , same as came from dealer two years ago
   / Alternator Belt
Na alternator get harder to turn as load increases , only parts the dealer change was glow plug , fuel relays ECU and starter wasn't doing this before I had it serviced...
   / Alternator Belt
Checked antifreeze minus fortythree ( -43 )
So that's not the problem......back to alternator, bearing going out , voltage regulator or starter shorting
   / Alternator Belt
Could see how no or little antifreeze could cause a problem
Used tractor most of the day with no trouble at all...outside temp in the 30s ....only time I have this problem is when I have to crank the engine more than 5 or 6 sessions
The last time it was 8 degree ...I have used the tractor 10 hours with many starts ( warmer temperatures only had to crank the engine over 1 or 2 times to get it to start....next cold day I have someone try start it so I can watch and see what's happening. Thinking it's most likely a bearing or a bad voltage regulator over taxing the fields in the alternator... just a guess.......thanks for all the replys at least I know what not the problem.....yes I checked each and every one...all were good points
Still looking
   / Alternator Belt #10
Dealer would be down there on his own time to figure out the problem. Looks like he threw a bunch of expensive parts at it though. Hope they weren't on your dime. I do realize that intermittent problems are hard to track down sometimes but that is ridiculous.
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2016 Ford Explorer...
2013 GMC 3500 HD Service Truck (A50515)
2013 GMC 3500 HD...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
International Farmall 856 2wd Tractor (A52128)
International...
