Alternator Belt
/ Alternator Belt
Don't really know ,sending out to a rebuild shop , never seen this type of problem before...thinking voltage regulator diodes breaking down in extreme cold conditions ....New alternator on now for over 24 hours Notice battery holding at 12.6 volts , will be out of town a few days will recheck upon returning.... it had been dropping below 12 volts with old alternator...even through diodes test showed good when checked , could still be leaking at colder temperatures...will see what the starter/alternator repair shop finds if anything.,. It turns free with no noise really don't think it's a bearing issue but could be wrong....
/ Alternator Belt
Will be dropping off at repair shop , hopefully they can locate the problem...Will keep as spare if repairable...
/ Alternator Belt
Amazing what brake-cleaner and a little elbow grease , will do ...actually this box is a mess , wouldn't pass inspection no way I could take inside a hanger but then again it's my home shop tools, a bit of a mess but clean and well taken care of...just saying
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
UNUSED RAYTREE RMH680 HYD HAMMER (A60432)
UNUSED RAYTREE...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
